Tc35/40 cold oil pressure issue
   / Tc35/40 cold oil pressure issue
It appears that 5w40 fixed the issue. Oil pressure light goes away in 1sec when cold now.
   / Tc35/40 cold oil pressure issue #12
I havent put enough hours on this machine to change the oil yet but will be doing that very soon.
First thing one a new to me car, truck, tractor etc is a complete fluid and filter change, grease all zerks etc.
The only thing I haven't done that on is my TC40D; I got it off consignment, where the dealer had done a full service.
   / Tc35/40 cold oil pressure issue #13
Did you change coolant, fuel filter, Hydro oil and filter etc? And grease the 35-40 zerks?
That was a change for me; my old [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] held less fluids, and only had 8 or 10 zerks, including the loader. When I got the TC40D about 12 years ago, I was amazed by how many grease points there are. The 17LA loader alone has more that my old [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] had for zerks!
Typicaly I do a full service when I buy something too. But the former owner said he just had it done, all the signs showed this also. New filters, clean fluids and the such.
Yes I have greased everything on the machine many times now..you would hope so with close to 100hrs.
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2010 New Holland TD5050 95HP 4WD Agricultural Tractor w/ Bush Hog 2610 10ft. Rotary Mower Attachm... (A55973)
2010 New Holland...
WACKER NEUSON RTSC3 TRENCH COMPACTOR (A52709)
WACKER NEUSON...
8 TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
8 TOOTHED BUCKET...
LOT: Receiver Hitches, 1/2 Ton Sheet Clamp, Pipe Threader (A59076)
LOT: Receiver...
set of 4 tractor trailer tires Roadforce (A56435)
set of 4 tractor...
