2305 John Deere hydraulics
/ 2305 John Deere hydraulics #1
Boznaros
Paola Kansas
John Deere 2305
I have a 2305 John Deere with a loader and belly mower. I dont have any auxiliary hydraulic. My issue is after the tractor has ran a while the loader slows down and I can’t get the mower deck to raise. Any suggestion?
/ 2305 John Deere hydraulics #2
How many hours do you have on this tractor? First thought with the little bit of information here is that the hydraulic pump is worn out. When the oil warms up and the oil becomes more viscous, the pump pushes less oil through the system lowering the pressures.
If I remember correctly it is a 2010 so not a lot of hours for this tractor
/ 2305 John Deere hydraulics #5
Not many hours for pump failure. The only way to determine what is going on is to put a pressure gauge on the hydraulics.
When the oil is cold, can you pickup the front of the tractor with the loader?
/ 2305 John Deere hydraulics #6
Following. Curious to hear outcome.
Yes even when it is warm it will pick up the front it is just slow doing so
/ 2305 John Deere hydraulics #8
Very interesting. What you say would indicate good pressure, just poor flow?
/ 2305 John Deere hydraulics #9
Have you checked hydraulic fluid level? Fluid condition, is it milky in color? Does this machine have a screen for the fluid? Just some initial things to go over.
/ 2305 John Deere hydraulics #10
Also, do you have to rev the engine to do this when the oil is warm vs idle to mid rpm when it is cold?
Level is good just changed fluid and filter last summer. Good color
/ 2305 John Deere hydraulics #12
Is the pump and or loader valve some place that is accessible? If yes does either one warm up quickly when trying to raise loader? A failing pump will typically get warm much quicker than rest of the system.
I believe the pump is inside the rear end and the valve is under the sheet metal
/ 2305 John Deere hydraulics #15
Is there a valve that controls the lift of the mower, like the 3 point hitch has?
/ 2305 John Deere hydraulics #16
I own a newer 2025r. Mine has both a hydraulic oil filter and a sump screen. Does yours have a similar setup? Did you clean the sump screen if you have one? They can get pretty gummed up. I’d still pull the screen and see what’s there. You will probably end up having to drain the fluid but you can reuse it if it’s clean.
/ 2305 John Deere hydraulics #17
Did you clean out the pickup filter also along with the spin on filter?
2305s have the loader/3pt hydraulics pump integrated into the hydrostat as a second piston pump riding on a fixed eccentric just below the variable piston pump coming off of the engine drive shaft.
They also have a linkage from the three-point that operates the belly mower lift so there's not separate hydraulics for the belly mower
I did not pull the screen. Didn’t know about it till after I drained and refilled the hydraulic oil. I will pull that. If nothing else to check for metal on the magnet
/ 2305 John Deere hydraulics #20
Yes. I don't think the screen itself is the problem. But yes, you will get to check for mechanical failure within the transaxle. I'm still optimistic that this is a valve issue. But I just can't quite explain how. Hoping for a easy/cheap fix.
John Deere 6420 (A64911)
John Deere 6420...
CAT 416F 36" Bucket (A68134)
CAT 416F 36"...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A67714)
2013 WACKER NEUSON...
Survey Kit (A64912)
Survey Kit (A64912)
(2) Rubber Skid Steer Tracks (A64912)
(2) Rubber Skid...
PALLET OF HOSES (A68842)
PALLET OF HOSES...
