Disc Harrow HOWSE LTR SERIES DISC MANUAL
/ HOWSE LTR SERIES DISC MANUAL #1
KHM65
Edna, tx
New Holland TC29
I recently bought a Howse LTR20822B disc. It is in good shape, I need to do a little work on it and re-set the blades to less aggressive. But I do not have an owners/user manual. Does anyone have a manual they can share with me?
Thanks a lot,
Ken
/ HOWSE LTR SERIES DISC MANUAL #2
Thanks a lot,
Ken
Ken,
I have recently bought the same disc, did you find the adjustment instructions? I have a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] L3200 to pull it with and think this disc is on the upper end if my tractor will pull it, comments please.
Thanks,
Tom
/ HOWSE LTR SERIES DISC MANUAL #3
/ HOWSE LTR SERIES DISC MANUAL #4
Howse Model DLHT 20822B
This 6 ft disc harrow has a powder coat painted heavy duty 2" X 3" tubular frame with 3" X 3" tubular arms. It comes standard with adjustable gangs, ball bearings, 1" axles, 7 1/2" spacing, double u-bolts, clevis style hitch, 18" blades, and is quick hitch compatible.
Discs with 7-1/2" pan spacing are designed for smoothing plow furrows.
If you have no interest in breaking new ground, and if your L3200 has 4-WD, the [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] L3200 should pull the Howse "OK". Certainly this disc is at the upper end of what your L3200 can pull on a second pass when the ground is soft.
Tractor weight is the key factor.
Less important factors are rear tire fill (air or liquid) and tire type (R1/ag tires provide better traction on dirt than R4/industrial tires).
/ HOWSE LTR SERIES DISC MANUAL #5
I have a Kubota L3200.
Kubota L3200
Kubota L3200 tractor photo
2011 - 2014
Standard L Series
Compact Utility tractor
Kubota L3200 Weight
2,425 lbs (2WD gear)
1099 kg
2,601 lbs (4WD gear)
1179 kg
2,623 lbs (4WD hydro)
1189 kg
