Grapple for Kioti DK40se (41hp)?
/ Grapple for Kioti DK40se (41hp)? #1
Gooch79
Graham, NC
Kioti DK40se HST
I have decided to get a grapple for my Kioti DK40se (41hp). I have bought several things from Everything Attachments and have been looking at their "Wicked Root Grapple 2.0," which seems to fit my needs. I will be using this to clean up trees and stuff from our property. Does anyone have any recommendations for the EA grapple, or any others? Also, what size? I am not an expert, so any help is welcome.
/ Grapple for Kioti DK40se (41hp)? #2
I have it on my 38hp Kubota. Its a great tool. I've used it to clear and move good sized logs in the woods as well as pick up some pretty big potatoes to be used as landscape features. For me it's a must have and a joy to use.
/ Grapple for Kioti DK40se (41hp)? #3
/ Grapple for Kioti DK40se (41hp)? #5
If you're looking to move heavy logs then you want to pay attention to the grapple's weight. The heavier the grapple the less log weight you can lift.
I have an EA wicked grapple, the long lower tine type. I think that's a good compromise for handling both logs and brush. If you're just handling logs there are dedicated log grapples which are lighter and cost less. Short tine root rake grapples might do a little better on logs but have less capacity for brush.
One drawback to the log tine style is that when I pick up a heavy log I may not be able to curl the loader back. The long tine puts the log's CG a bit farther from the pins if you picked the log up from above. This may not be an issue for another loader. A few times I have ended up carrying a log with the grapple facing down.
I have a 60" wide grapple and could have gone with a 55" or even 50". I thought I'd be able to grab firewood rounds with the grapple and wanted the extra width for that but it turns out that's not easy. I changed how I process wood so I don't do that unless the logs are so large that the grapple's jaws won't go around them. For logs and brush a slightly narrower grapple would work just as well.
/ Grapple for Kioti DK40se (41hp)? #7
Have 54” wicked on the [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] B26 and love it. Don’t want your grapple too wide compared to a GP bucket. Dual lid, long bottom a must for my brush work.
Added front grill protection a must have.
/ Grapple for Kioti DK40se (41hp)? #8
I had my dealer install a 4 foot CID grapple on my little 23 hp Massey. He did all the hydraulic hook up. I have a little rocker switch on the loader joy stick . I can operate everything with one hand. I love mine and I bet you will love yours.
/ Grapple for Kioti DK40se (41hp)? #9
I am currently shopping for a grapple for my 40 hp tractor. I am leaning towards this one.
/ Grapple for Kioti DK40se (41hp)? #11
I've had my Land Pride SGC1560 grapple for nine years now. It's an uber HD grapple and has held up well. I can attest to the quality of Land Pride grapples. I use mine to move large rocks and chunks of pine tree trunk. What SmokyDog says/posts about mods to your grill guard is VERY important. Stobs, stick & limbs have a very nasty way of damaging your grill, radiator or battery. This is my grapple and modified grill guard.
/ Grapple for Kioti DK40se (41hp)? #12
Tomahawlk and express steel also make grapples. Both made in the US. Both will be quite a bit cheaper than other brands mentioned here.
I have a 66in tomahawlk I got with my tc40. I got it used from a company that put lawns in, so it was used commercially yet I dont see any issues with it.
/ Grapple for Kioti DK40se (41hp)? #14
I got the EA 60"?? for my DK40HST. It's nicely made and looked better in person than pictures. The gaps are a little large when trying to pick up firewood. Sometimes I think it might have been better to get the dual lid unit. One positive is I can close the lid and use the whole thing centered like a fist to push on something.
/ Grapple for Kioti DK40se (41hp)? #15
I just got a Titan/Iron Craft 60” for mine. So far it seems to be everything I need. I ran hoses to my rear remotes, so no 3rd function valve.
/ Grapple for Kioti DK40se (41hp)? #16
I have a Versatech 5' grapple on my DK4210 and its a great fit, nice heavy duty rig for logs, brush, rocks, best attachment I own,,
Walter
