Oil & Fuel Cold rookie mistake
/ Cold rookie mistake #41
I add anti gel as soon as temps hit 40 degrees and have not had any problems over the years. Start adding anti gel early, it's worth the the extra money in aggravation. For your problem I would drain the tank and add winter diesel with anti gel; if you have a way to tarp your tractor and add a good heater you wont have to change your fuel filter (s). Let it heat up good and once started run it long enough to disperse all the untreated fuel from the system, that should do it.
/ Cold rookie mistake #42
I use power service year round and don't
have any problems with gelling. So always
ready for the cold snap
willy
/ Cold rookie mistake #43
willy
In Texas? When was the last time fuel gelled there?
/ Cold rookie mistake #44
It can happen in the Panhandle I would think.
/ Cold rookie mistake #45
My nephew on the farm in SD tells me he often runs #2 diesel all winter except for a few cold days - although he does use some additives in the #2. We didn't do that when I was younger. He said some of the additives are so good he rarely has issues.
I wouldn't think there would ever be a time in Texas that you would need to worry about it unless the fuels are different there.
John Deere 5300 (A64911)
John Deere 5300...
2012 Volkswagen Passat (A66738)
2012 Volkswagen...
2007 FREIGHTLINER CL120 6x4 T/A DAY CAB TRUCK TRACTOR (A59914)
2007 FREIGHTLINER...
10' Sheets of Tin (A64912)
10' Sheets of Tin...
2010 RU SYSTEMS SMART 850 SIGN TRAILER (A66091)
2010 RU SYSTEMS...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
