   / Share Pics of People Hauling or Towing Something Wrong #17,501
This is what I use. You should know the approximate weight of the trailer and load. I move it around until the tongue weight is between 10 and 15 percent. Then tie it down. No guesswork.
I also do this. It works REALLY well.
I load my tractor "backwards" whenever possible. It prevents the hood and doors from being damaged if they are not latched correctly. Some of the glass cab doors are crazy expensive.
   / Share Pics of People Hauling or Towing Something Wrong #17,502
I know with some JD’s they worry about the hood opening and getting ripped off so they load backwards.
I'd get around that by strapping the hood down with a bungee cord or two.
Since this is a thread about poor towing and hauling practices, here is my old 1025R ready to come home for the first time. I purchased it local, and only had to drive a short way; that doesn't make up for too small a trailer, and no tow straps. Foolish, but I drove it the 10 minutes at 20-25 miles an hour, with the hazards on.
It's not an experience I've ever repeated.
   / Share Pics of People Hauling or Towing Something Wrong #17,503
It seems pretty likely that the load moved. My guess is that they took off a little briskly from the intersection and the load shifted rearward. I doubt whether that's where they positioned the load and started the drive. I think the better question is "how about properly securing the load". I'm betting the slabs are strapped to a carrier but the whole thing wasn't strapped down to the trailer. "It's heavy... it will say put." Oops...
This guy does a good job explaining the situation for this failure:
He neglects the camper overhang on the rear . Some people will slide 4 ft extension in the receiver to pull a boat ? Kevin .
   / Share Pics of People Hauling or Towing Something Wrong #17,504
That is a good explanation. I can't imagine a 4500 to 5000 lb dry weight camper, does someone make such a beast? I am backing off getting a 2800 lb dry weight camper for these reasons.
Dry Weight of an Eagle cap 811 is 3380 lb. I wonder if he intended to say gross.
Edit: HOLY CARP. An Eagle Cap 1160 is 4659 lbs dry. Model 1165 4917 lbs !!!
   / Share Pics of People Hauling or Towing Something Wrong #17,505
Yeah, some truck campers are just silly, they make some with 3 slide outs (mostly the ones with the door on the side like the one on that Dodge), they get dumb heavy and stupid expensive... my camper is around 2500lb dry I think, I like to stick to the 9' length range so towing works better, I've had a 11' camper with a 4' hitch extension and that's too much to tow comfortably...
   / Share Pics of People Hauling or Towing Something Wrong #17,506
The forklift hasn't let the full weight on the truck yet!
   / Share Pics of People Hauling or Towing Something Wrong #17,508
I think there are 90x cmus in a full pallet. ~3500 lbs.
   / Share Pics of People Hauling or Towing Something Wrong #17,509
You must not have watched the full video. He mentions that multiple times.
   / Share Pics of People Hauling or Towing Something Wrong #17,510
If that's cmu it's almost 40lbs per block x 100+ can't remember how many are on a pallet though.
I can't see a pallet on the truck, looks to me there is one beside the truck though. Full disclosure, my vision isn't very good though.
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
club car (A56859)
club car (A56859)
Brush Cutter Mini Skid Steer Attachment (A56857)
Brush Cutter Mini...
CATBKTSSL_78 (A55787)
ROBIN AIR 34788NI A/C RECOVERY MACHINE (A58214)
ROBIN AIR 34788NI...
2004 Ford Explorer Sport Trac Pickup Truck (A56858)
2004 Ford Explorer...
