105A caution light
/ 105A caution light #1
av8tr72
Member
Case 105A
I have a 105A. A couple of times I have started it to warm it up. I noticed the yellow caution light will come on. Yellow light with the exclamation mark. I also noticed that the engine will rev up on its own. It will run about 500 rpm ( I believe) at idle but it will go up 1000 rpm on its own with out touching the throttle at idle. If I push the throttle up the caution light will go away. Called dealership and they said it could possibly doing its regen and to run it at higher rpm for a while. Ran it for a couple of hours and seemed to do fine, could run at idle for a bit after done and did not see the light.
Two days later I started it again and it did the same thing when starting it to let it warm up. Start, while idling it will go up to 1000 rpm on its own. Anyone ever experience that?
I followed the book to try to figure out how to see a possible code, I could do better closing my eyes and pushing buttons. Anyone know the step by step instructions for finding codes?
/ 105A caution light #2
Have you resolved this issue?
HAMM H12i ROLLER (A65053)
HAMM H12i ROLLER...
2017 Ford Expedition SUV (A61574)
2017 Ford...
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2010 Sterling A9500 T/A Day Cab Truck Tractor (A61568)
2010 Sterling...
2023 CATERPILLAR 262D3 SKID STEER (A64279)
2023 CATERPILLAR...
Husqvarna MZ61 Zero Turn Mower (A66285)
Husqvarna MZ61...
