Filter for diesel storage tank
/ Filter for diesel storage tank #1
shooterdon
Super Member
Near Johannesburg MI but in the middle of nowhere
2019 LS XR4140 HST Cab; 2025 Moto UForce 1000; 2021 Bad Boy 54" ZT Elite
/ Filter for diesel storage tank #2
I run 2 filters on my tanks.
A 5 - 30 micron - depending on what's available and then a 2 micron before the hose.
/ Filter for diesel storage tank #3
Find one that has 3/4" inlet and outlet. ( your picture show a 1" inlet and outlet) That is the pipe size you have on the Fillrite. And yes, you should put it on the outlet side as not to restrict the suction side. You can also stop by Tractor supply and see what they have and you can get an idea of the size as well.
/ Filter for diesel storage tank #4
I use a 10 micron water blocking filter on my transfer tank. It's a Goldenrod spin on and head available at TSC or Amazon.
/ Filter for diesel storage tank #5
My local NAPA has them, or you could get a remote filter base. The dedicated ones for diesel transfer pumps would be your best bet. They have the water separator.
I’m pretty rural, and there are a lot of guys with transfer tanks in their trucks. So, the farm and ranch supply, and autoparts stores all stock them or can get them out of Salt Lake the next day by 1000.
/ Filter for diesel storage tank #6
I'm switching to 1" tank filters. Because I've been having issues finding 3/4" filters in the 2 micron rating.
This reminds me, I need to call Cimtek get part numbers and order a 1" filter head and 2 micron filters.
/ Filter for diesel storage tank #7
I wouldn't use that particular filter setup either unless you already have a machine with those filters. The filter threads are 1-1/2" and you'll be paying extra for that. I'd get a common size or match your equipment. Most will be 3/4" and some 1". That way you can keep common filters in stock.
On a side note: Has Fill-Rite really gone that cheap--Plastic fillers?
/ Filter for diesel storage tank #8
Where are you finding 3/4" npt tank filters?
I'm buying a 1" filter head because I'm having trouble finding 2 micron tank filters.
I like to have the fuel filtered before it goes into my stuff.
It saves a lot on changing the more expensive equipment and vehicle filters.
With the double inline filters, I don't have to change filters very often.
/ Filter for diesel storage tank #9
I was speaking of the fuel filter setup like the OP linked to--Not in tank filters. The filter in his example has 1-1/2" threads. Try finding those at a local outlet.
/ Filter for diesel storage tank #10
That's the style filter and housing I use.
The filters I use are 1" npt.
I had several 3/4" npt filters, but have had trouble finding replacement filters in the micron ratings I want, so I'm switching those to 1" npt filters like pictured.
/ Filter for diesel storage tank #11
Goldenrod here too. You can see the filter element and quality of fuel along with any water at the bottom of the bowl.
/ Filter for diesel storage tank #12
My local NAPA stocks quite a few, and can typically get the ones they don’t have the next morning.
/ Filter for diesel storage tank #13
I had the Goldenrod sediment bowl type for a number of years, but the one I have now is a cannister type by Goldenrod. The sediment bowl types are nice to monitor fuel quality and potential water contamination. They also have a water blocking element for them, but last I checked the optional water blocking element was rated at 30u for particulates. I suspect the optional water blocking element is not necessary in a sediment bowl filter though.
/ Filter for diesel storage tank #14
I've had good luck with 2 filters in line. The 2nd being 2 micron.
I don't have to change them very often
/ Filter for diesel storage tank #15
I use a 15gpm pump, so unlikely I could filter down to 2u at that flow rate. My tractor now has a 2u filter / separator, so I'm satisfied with 10u from the transfer tank.
/ Filter for diesel storage tank #16
I have no idea why a 15 gpm pump would make a difference. I prefer to have my fuel filtered as well as possible before it goes into the equipment.
/ Filter for diesel storage tank #17
You are correct. I assumed 15gpm was too high a flow to filter down to 2u. CimTek seems to make a 2u water absorbing filter that can handle 25gpm. I'm going to check if the filter height will fit where I need it.
/ Filter for diesel storage tank #18
Do you guys have any ideas on how to attach a filter to a 55gal drum?
/ Filter for diesel storage tank #19
/ Filter for diesel storage tank #20
Looks good but I have an electric pump with hoses.... I guess it could be hard plumbed in (y) and a filter added like you show. OR maybe I should just break down and buy the rotary pump. Argh
2006 MACK CV713 (A67714)
2006 MACK CV713...
2022 LEVEL BEST GB100 108" HYD GRADER BLADE (A65053)
2022 LEVEL BEST...
2025 CATERPILLAR 285 SKID STEER (A65056)
2025 CATERPILLAR...
1991 26ft Pursuit 2350 Walking Around Cabin Cruiser with 2017 21ft S/A HMDE Performance Boat Trai... (A66738)
1991 26ft Pursuit...
2004 FRAC TANK 500BBL WHEELED (A68842)
2004 FRAC TANK...
Generator (A64553)
Generator (A64553)
