Post your Branson at work. Picture thread
/ Post your Branson at work. Picture thread #182
I expect that the top bale on the first stack, fell not to long after the video.
/ Post your Branson at work. Picture thread #183
Around here about all you can get anymore are big bales. That is great if you are a large farmer but they sure suck if you have just a few animals.
/ Post your Branson at work. Picture thread #184
its a little angle. still up there. it is tight on the porch for now with the large squares. I don't mind this size. We fill tote cages with hay for our 6 sheep and a llama. forks to move the cage to the hay, fill up and then fork it back out to the pasture.
/ Post your Branson at work. Picture thread #185
Next season I'll have to figure out something better for weight, but the sand bags work OK for now!
/ Post your Branson at work. Picture thread #186
Just curious if your rear tires are filled?
I've been thinking about a front push box for snow, but still on the fence.
/ Post your Branson at work. Picture thread #187
No, but that will be something I have done before next winter. I thought the heavy duty rear box blade would be enough weight but it wasn't. After adding about 1000lbs of sand on top it works great.
As far as the front box plow, it's great for things like wide driveways and short runs. However, for something like a street or long driveway it would be better to have an angled plow that can move the snow off to the side. I have both a long driveway and a large area to clear so I have to stop, turn to the side, and dump snow several times along the long driveway after the box fills up. Kind of a pain but it's easier than buying another plow and switching back and forth.
/ Post your Branson at work. Picture thread #188
Are your tires siped at all, or are you just going bare there?
Is that snow cold & dry?
/ Post your Branson at work. Picture thread #189
Nice canopy you have there! It looks real good on your machine.
/ Post your Branson at work. Picture thread #191
They are unmodified stock industrial tires. It works pretty well as long as the weight is there, but siping would probably help too. During the picture the snow was very cold and dry. With wet snow they slide around once it's packed down.
Yeah I like it a lot, and it can flip around to the other side when I'm doing backhoe work. It's a Rhinohide: Tractor Canopy - Rhinohide Canopies
/ Post your Branson at work. Picture thread #192
Hey, technically, it was a gate.
:rolleyes:
/ Post your Branson at work. Picture thread #193
No pictures of the tractor, but a few of the work she did;
got a load of mixed sand and salt delivered today, had to push it up in the pile and add a bit more salt (500 pounds more)
pushing it up in the pile with a bit of salt
sprinking the last four bags on the face
all mixed and pushed up
covered and ready for use
/ Post your Branson at work. Picture thread #195
been alot of that around here also! spent a fair few hours this week plowing.
/ Post your Branson at work. Picture thread #198
Today I tilled around my freshly planted olive trees. This area was actually nice and dry enough to work on. The rest of the land, not so much.
If you squint hard enough, you should be able to see the olive trees. 🤣
/ Post your Branson at work. Picture thread #200
View attachment 782044 View attachment 782045
I've wondered if I should till in my orchard. What's the advantage?
20 GALLON SPRAYER, 12V (A64278)
20 GALLON SPRAYER...
2018 CASE TV380 SKID STEER (A65053)
2018 CASE TV380...
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A64556)
2022 East...
Deer Staute (A64557)
2023 WACKER NEUSON G70 TOWABLE GENERATOR (A63276)
2023 WACKER NEUSON...
UNUSED 2023 JCB S3246E ELECTRIC SCISSOR LIFT (A65053)
UNUSED 2023 JCB...
