Good morning!!!!
   / Good morning!!!! #162,122
Alien - have fun at the club- how is the hand, did the surgery help?
Hands are not healing as quick as I had hoped. Still got a ways to go. Both thumbs still have bad pain further back in the joints. Hospital wants to see me on 5th Jan. Not long to wait.
   / Good morning!!!! #162,123
Looking at installing more of the barn gooseneck lights. Did one last year. Two more to go. Was finding in one of the drawers the hole saws and it looks like the big Lenox hole saw will work for the junction box. The last one installed I used tin snips to cut through the steel siding. I don't know if the hole saw will work in steel siding or I should just go back to using a tin snip
   / Good morning!!!! #162,125
Buckeye, try to look busy. You don't want your wife to think you are bored. Sometimes it seems if my wife thinks I'm bored she finds things for me to do. o_O
Chris
Good point, I’m sure she will have a list regardless of what I’m working on. She already wants new light above the sink. Have a 3 ft fluorescent one that sometimes doesn’t light, then I broke a plastic socket base the other day
   / Good morning!!!! #162,126
The issue with cutting profiled siding with a holesaw is keeping it centered if the pilot drill is not on a raised section. In that case, I have had good luck with cutting a hole with the holesaw in a piece of 3/4” plywood and then clamping or screwing that to the surface to be drilled, using it to guide the holesaw. It works well when cutting a hole bigger and there is no meat for the pilot bit as well.
   / Good morning!!!! #162,127
Sunday high was 69F and Balmy 70today today..
   / Good morning!!!! #162,128
BEF- When I retired, there was no hiding from the 'honey do' list. I also found I was never busier, I have said to friends, "If I knew I was going to be this busy in retirement, I would have stayed working!!" At least I am busy doing what I enjoy, hopefully you will as well.
   / Good morning!!!! #162,130
Trails End glad you stopped by new bear pictures?
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
MASSEY FERGUSON 4710 TRACTOR (A59823)
MASSEY FERGUSON...
NEW Woods 6ft Finish Mower (A56438)
NEW Woods 6ft...
159120 (A60430)
159120 (A60430)
1605 (A57192)
1605 (A57192)
