rScotty
Super Member
- Joined
- Apr 21, 2001
- Messages
- 9,752
- Location
- Rural mountains - Colorado
- Tractor
- Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
That's interesting. I'll bet when you got those 2 to 4", worked the valves, heard the fluid move, and saw it hold in the new position you thought it was going to be easy... I know I would have.
First of all, I don't know. But here are three guesses:
1. One is that the cylinder shafts were really corroded and where they began to enter the cylinder body they are now jammed in that bushing and won't move. The problem with this, is that hydraulic cylinder shafts have a wiper, don't corrode easily, and you probably cleaned them up a bit when you saw it might move.
OR
2. Your jacking force should have caused some fluid back through the return line to the hydraulic sump when you worked the valve. And it must have done so, after all you heard something happen. And now for some reason the return line is not accepting fluid. I don't like this idea because the one part of a hydraulic system that is always working has to be the return. Otherwise big danger. So returns are over designed. But it is simple to figure out which line is the return, and loosen the fitting to see if fluid sprays out.
OR
3. Maybe your jacking force cause fluid under pressure to leave from the compression side of the hydraulic cylinder, and for some reason the valve didn't do it's other job - which is to allow some fluid to go into the side of the cylinder closest to the ram and now you have a vacuum lock there. That's why you can lift it a little and it returns to where it was.... and why you cannot get the valve to move any more fluid.
I like this last idea the best. So put some force on it, loosen the hose fitting on the ram side of the cylinder to let some air in, and see if working the valve makes fluid flow now.
READ!
BTW, I'm going to assume that when the engine runs, the hydraulic pump turns, and and you have checked somehow to see that you are actually sucking fluid into the hydraulic pump and returning it to the sump. If not, lets back up right now and you should immediately think about what I'm sayng next.
Most hydraulic problems are one of three or four things, and all of them end up starving the suction side of the hydraulic pump. One is too little fluid, another is a cleanable screen clogged, or a clogged hydraulic suction fllter, or most common of all is an air leak in the suction hose between sump and pump. that air leak can be tiny and impossible to find. Cure is to replace hose.
You know it is returning properly when you can undo the return line and put it into a bucket, start the motor, and then quickly stop before you pump all your expensive hydraulic fluid all over the ground.
Or make up a section of clear vinyl hose - there shouldn't be any pressure - or nearly none - in the return flow....only flow.
Luck,
rScotty
OR
OR
READ!
Luck,
rScotty
