Mahindra 5145 or Branson 4820R
/ Mahindra 5145 or Branson 4820R #1
murraya8922
Mahindra 5145
Hey folks, pulling the trigger on my tractor in March. That's when I'm actually moving onto my land.
I've narrowed it down to the Mahindra 5145
Pros:
-Heavy heavy tank
-400 pounds stronger loader
-Test drove and really like it
-4 dealers within two hours
Cons:
-Shuttle only
-MCRD
-ECU ran engine
And Branson 4820R or H
Pros
-NO ECU
-DPF filter can "fall off" and it wouldn't effect function or warranty. (There is a factory bolt on muffler that can take it's place)
-"Cummins" KukJe? engine
-About 5 grand cheaper(HST)
-Available with hydrostatic transmission
-6 year warranty as opposed to 5
Cons
-Lesser known brand
-Only 3 dealers with 2 1/2 hours
-Aquired by TYM, so long term parts may or may not be an issue
-Lighter, but at almost 6,000 pounds with loaded tires, that's really okay
-Weaker loader, but can still lift 2,700 pounds, so I can't complain
Bottom line is that both of these machines are overkill for my 6.5 acre wooded lot, but to get the beefy loader I want I have to go big. About 40 PTO horsepower will be sufficient for a 6 tiller and that's all I'll ever need.
I will 100% be doing a lot of loader work the first couple of years, so hydro is better, but don't think that need to make or break the deal with the Mahindra being shuttle shift.
If anyone can include their experience, or more positives and negatives that I might have missed, I'd sure appreciate it!
Thanks as always folks. So happy I joined this forum.
/ Mahindra 5145 or Branson 4820R #2
Can't speak to the Mahindra, but can give info related to the Branson. That 20 series Branson is built on the same frame size that my 25 series is built on. If you're looking at a brand new one, it also has the "upgraded" cab like the 25 series came with.
Your 6000 lb weight estimate sounds too light to me. With a FEL and bucket on the front, and my rear tires filled, with a light box blade on the 3 pt, I'm right at 7100 lbs. I think you will be pretty close to that weight. It may not matter, but then it depends on what you're doing. For instance, I cannot drive my tractor over my septic field. Also, you may need to factor this in if you're looking at towing weights if you plan on being able to haul your tractor anywhere.
The newer Bransons (2020 and up, I think?) have a different emissions system. It's still a DOC/DPF, but they've added a butterfly valve on the exhaust outlet to close and heat up the DPF filter when the filter gets partially plugged. You do this by pressing the "regen" (or whatever they call it) on the dash. The older Bransons don't have this butterfly valve. If the one you're looking at is new, it should have the valve. Branson has redone their system so you can't just take the filter off. Well, actually you can, but the DPF warning light would be on. Disconnecting the Data Logger (we could do so on the older system) will also stop your gauges from working (temp, and tachometer that I remember-possibly more?).
But being able to forcibly increase the heat in the DPF by performing this "regen" may also mean that you never have any issues with it. The old system did not allow for any way to add additional heat to the filter.
That FEL rating is "at the pins", just so you know. The farther forward your weight is from the front pins, the less you can pick up. My loader spec is 2200 lbs at the pins, and I regularly pick up 1400-1600 lbs with it. Those are usually on pallets, etc, so those weights are quite a bit forward of the pins.
About all I can think of for now.
Thank you for the response! Didn't realize they added the butterfly valve or that it shared the same frame as the 25 series.
It being mechanically injected still is a huge selling point for me.
How has yours served you and how many hours?
One point my coworker brought up to me this morning:
Distance to dealer is discussed very often, and I understand why. But what if I move from TX to ID in a few years? It's a legitimate possibility, so distance to dealer would be somewhat irrelevant at that point correct?
Only thing I can thing is that it proves that point that having lots of dealers around the country, like John Deere, is an advantage.
/ Mahindra 5145 or Branson 4820R #5
I'd probably go with the Branson if you have dealer support. The Mahindra is a nice machine but I'm not a fan of direct injection. I have a shuttle shift and I like it but I do a lot of field work. If I was doing mostly loader work, I'd go hydrostatic. I do know Mahindra has nice front end loaders.
/ Mahindra 5145 or Branson 4820R #6
Depends on how often you need your dealer to do something. So far in 5 years of ownership my Branson 3725 has not been back to the dealer. All I have had to do is regular maintenance. My dealer is 3 hours drive away but they answer email and pick up the phone and ship me the stuff I need.
My dealer also sells Mahindra and I originally wanted one. It was in the mid 30 hp range so a different model than you're looking at. While some aspects were better like a lower seat height and less effort on the HST pedals the overall build quality was not even close. The kicker for me was hearing that there'd been a number of ECU programming upgrades and I'd have to bring the tractor to the dealer to get that done. Just not practical for me.
I like my Branson and have no plans to replace it. But if I was do to it over I'd likely spend the extra $10k for a nice Kubota Grand L series. I get a lot more use out of the tractor than I expected I would and could justify the more expensive machine with more features.
With the current 20 series Branson addressed all the issues I have with mine- four range speeds instead of three, the ability to command a regen (though I have not needed to or had a problem with my DPF) and moving the front axle vent that leaks oil if you operate on slopes (not a problem for most people).
/ Mahindra 5145 or Branson 4820R #7
the Branson looks like a nice package, the Mahindra will be about 2000# heavier 1560# for tractor and the loader is heavier, that may be a + or a -. The 5145 is a tank and even without loaded tires it is very stable. if you really want HST you will have to go with the Branson, as far as loader capability there is a large difference between the Branson and the Mahindra and the weight diff makes for a whole different experience. dealer location was the main reason i did not look more closely at Branson and if you move to ID i do not think that Branson dealers are going to get easier to find. I would sit on a branson before i bought one, but looking at the specs i think i know which i would have chosen if dealer location was not an issue (still the 5145) but YMMV.
It looks like rear remotes are an option on the Branson, I would check into that before i made a decision, it may make a significant price difference.
the R4 tires are bigger on the Branson which is nice the turning radius is shorter also.
the digging depth on the FEL as well as the pin height is better on the Mahindra.
good luck either will probably do what you want. i think the HST is most likely the deciding point.
Compared to the green or orange tractors, both of my options absolutely stomp them in the dirt for significantly less money. For example, the 4044M tractor and loader only is the exact same price (recent quotes on both) as the Branson 4820H...with a tiller, box blade, brush hog, landscape rake, grapple & third function and an auger! I mean, if feels more risky, but the price difference is very significant.
I just haven't seen ANYONE on here say that they wish they didn't get a Branson, or they are junk. I believe in buy once cry once, but I also don't pay for paint and logos. Tough decision!!
I checked the resale on the Branson tractors, and was pleasantly surprised to see that they weren't too far from MSRP new. Leaning heavily towards the Branson.
/ Mahindra 5145 or Branson 4820R #9
Both Slim and Eric have given good information. You have to consider when purchasing any new tractor that utilizes an ECM to control the ignition, fuel injection, monitor sensors, and regen cycles, puts you at the mercy or beholden to a dealer. Code readers, check engine lights, limp mode all become a reality at some point in that tractors future.
My tractor is used for farming. The thought of dealing with check engine lights and or limp mode during the busy season of mowing , haying, or spraying is not even remotely doable, even if under full warranty. I bought the Branson brand almost exclusively for the reason of the simplicity of the mechanical injection and no ECM. I have owned it now for 18 months and have logged over 300 hours. Buying a tractor with a small market share certainly a risk, fortunately no regrets, solid robust tractor.
You said it perfectly! I am fairly certain I'll go with the Branson strictly based on the no ECU and mechanical injection alone. Especially with the low market share type of tractors. I've heard the majority of problems being electrical with these. A tractor should be simple. Diesel engine and hydraulics. I want it to work and be able to be fixed without a computer. Don't feel like I'm asking too much, ha.
I'm going to "test drive" Bransons as soon as I get off of this job, and I'll make up my mind then.
Thank you for response and knowledge.
/ Mahindra 5145 or Branson 4820R #11
You probably already know this, but worth mentioning since you say that being mechanically injected is a huge part of your buying decision. It was for me, too.
It's easy to tell a mechanically injected engine from a common rail type if you want to check to be sure. The mechanically injected engine will have a separate metal tube injector fuel line going from the fuel pump to each injector. If it is a 4 cylinder engine, there will be 4 separate fuel lines, one for each injector.
A mechanically injected engine has to have separate lines because each injector is triggered by a timed pressure pulse from the injector pump.
The other type - more common today - is the "common rail". In the common rail engine, a single fuel line from the fuel pump keeps a common rail constantly pressurized. Injectors are triggered electrically - usually by an engine computer.
On direct vs indirect injection....that's entirely different from type of injection. Some diesels are direct injection and some are indirect injection - but those are features of how the combustion chamber is shaped inside the head. You cannot tell from outside which one it is - and there have been equally good engines built with either head configuration for a long time now.
good luck with your tractor choice.
rScotty
rScotty
Great information, thank you! I'll definitely look at the lines coming from the fuel pump. Avoiding the common rail if at all possible.
From what I've seen and read, even the larger Branson tractors with over 25HP are still mechanical as the use the A series KukJe? engines. Which I've also heard nothing but good things about.
/ Mahindra 5145 or Branson 4820R #13
The Bransons up through 20 series are all Kukje licensed Cummins A series engines. The 25 series was very similar to the 20 series and also used the A series engine, but a 2.1L A2000 with smaller bore than the A2300 in the 4X20 and 5X20s.
To be fair, common rail and EFI are well established technologies now, as are DPFs. Branson is unusual with their low temp constant regen DPF system. It seems to work well if you get the engine hot enough often enough. That's been no problem for me but it does not get that cold here and snow is rare. Some folks in places that get cold and who can't do much with the tractor in the winter have had problems. I think that's why Branson added the ability to command a regen.
Above 75hp the emissions requirements tighten and that's where you see DEF and EGRs being common. Those are the two technologies that seem to cause the most problems. Below 75hp DEF is not used and EGR is not common.
There are a few manufacturers or models that have had problems with their emissions system. The Kubota B3350 comes to mind. That was also a mechanical FI system but different from Branson's. Kubota stopped making them. From reading some of the manufacturer specific sections here I sometimes see people complain about frequent regens with some makes/models. Some of that may be the operator not running the tractor hard enough, some may be manufacturer specific.
If you wanted a different make I would suggest reading the forum for them. But its likely that those tractors perform well with no emissions problems. And I certainly would not discourage someone from getting a Branson, as long as you're ok with having fewer dealers and parts sources than say Kubota.
I'm a big fan of OBD2 ports on cars along with a good reader or software that can handle manufacturer specific codes. I think the extra information is worth the learning curve, and I started working on vehicles back when they had points and condensers. But emissions laws do not require them so few compact tractors have useable OBD2 ports.
/ Mahindra 5145 or Branson 4820R #14
May I ask why you aren't consider Kubota or John Deere?
/ Mahindra 5145 or Branson 4820R #16
I bought my 4820R in March 2021 and put 285 hours on it. It's been a great machine. The closest Branson dealer to me when I purchased was 100 miles away. I had a fuel leak right after I got and the dealer repaired it without any hassle other than taking it back to him. It has done one regeneration at 160 hours. The shuttle shift is my preference and I've moved a lot of dirt with a box blade and loader bucket. When I bought it, I added the 3rd function and 2 sets of rear remotes. Too use all the loader capacity, you will need to fill the rear tires or put a heavy implement on the rear as a counter balance. Without any extra weight on the back end, the tractor has no problem lifting the rear tires off the ground.
My tractor with loader and backhoe was 25% less than an equivalent orange tractor with just a loader. The green tractor dealer didn't care. The Branson dealer spent a long time on the phone talking to me and answering questions as well as a long time the first time I went to look at the Bransons. I almost went with a MF, but the dealer could only much smaller or much larger tractors at that time. I also considered LS and Mahindra. The 4820R had features and capacities that fit my needs at a good price.
/ Mahindra 5145 or Branson 4820R #17
That just means it takes slightly more work should the DPF system have issues to be "mitigated". My preliminary "just in case" investigation for my TYM indicates it will involve fooling a couple of pressure sensors which isn't all that hard all things considered. It may as well be a federated system compared to single ECU controlled systems.....
/ Mahindra 5145 or Branson 4820R #18
the right tractor is the one that is right for you, you are doing your homework and that is great, be sure to sit on and operate the tractor you think you want before putting the money down on it.
good luck!
/ Mahindra 5145 or Branson 4820R #19
good points, also keep in mind that filling the rears is good in that it does not add load to the rear axel but it does not unload the front axel like counter weight does (wile adding load to the rear axel)
43024 (A59228)
43024 (A59228)
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
For Sale, Shrink Wrap Kit for implements, tractors, boats etc.
For Sale, Shrink...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
Caterpillar 24in Digging Tooth Bucket Excavator Attachment (A59228)
Caterpillar 24in...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
