Hydraulics all froze! What to do?
/ Hydraulics all froze! What to do?
Thanks for the comments everyone!
A neighbor got me through the storm. Yesterday was 34F and everything worked perfect. So clearly not the pump. I’ll get 2 new filters and new oil that can take the cold.
What are some of the recommended oils for low low temps? And will a low temp hydraulic oil still perform properly in 100F temps???
Thanks
/ Hydraulics all froze! What to do? #13
Another reason to avoid hydrostatic machines. I want a lever I can shift with a clutch pedal to shift it.
This isn’t hydrostatic tractor??? 12 gears. Power shuttle. Clutch
/ Hydraulics all froze! What to do? #15
Believe me, after operating a CVT for about 5 years, you’d want one.
/ Hydraulics all froze! What to do? #16
A gear drive can suffer from poor maintenance too. Swifty said he bought it used, so lord knows what was done to it in the past.
I've never had an issue with HST's and have many hours on them.
/ Hydraulics all froze! What to do? #17
Water will still cause damage to the hydraulics. A high enough percent could crack the case when it freezes. If there was ever a stupid reason to avoid HST this would be one.
/ Hydraulics all froze! What to do? #18
If it wasn't making the machine go to and fro, the lift would work. Besides, the lift worked a little. Complaint was that machine wouldn't move. Never had a hydrostatic tractor, I've never had a lift that wouldn't work. We see negative temps, but not every year.
/ Hydraulics all froze! What to do? #19
I’m sure he would feel all better if he could drive the tractor in the direction it was heading since the steering didn’t work and wasn’t able to lift the bucket either. The fact you’ve never had a HST is just proof that you don’t know what you’re missing. And there’s thousands of skid steers and HST tractors plowing snow in the cold everyday so obviously they do work in the cold. There’s dozens of post on here of clutches sticking. Clutches fail and require fairly extensive labor to repair. I’ve had slave or master cylinders fail on 3 separate trucks, once catastrophically that lead to being completely un drivable. Gear transmissions aren’t as reliable as you gear guys claim. They make other transmissions that offer a better mix of beings friendly to use and not robbing power but then you’ve lost the cost saving or simplicity debate.
/ Hydraulics all froze! What to do? #20
I worked for Kubota/New Holland, made my decision then.
2005 FREIGHTLINER THOMAS BUS (A59823)
2005 FREIGHTLINER...
2008 DOOSAN G25 GENERATOR (A58214)
2008 DOOSAN G25...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2022 CAT 289D3 (A60462)
2022 CAT 289D3...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
ALLMAND LIGHT TOWER (A60736)
ALLMAND LIGHT...
