Good morning!!!!
   / Good morning!!!! #161,782
Good Morning
It’s 25 with a high of 36 today. First time above freezing since Friday.
Yesterday kept me busy, had 3 heaters to fix, was able to get 2-1/2 fixed. First was a geo thermal with a bad capacitor on the blower motor, I had one in the KubVan. Next one was an inducer bower impeller on a gas furnace, fortunately the one inducer assembly that I had was the correct one. The last one was a gas furnace with thermostat issues. It was a proprietary thermostat that I didn’t have, but was able to rig up a switch to run it in heat mode so they could manually control it and have heat until the part arrives.
Not sure what today will bring, might go with a friend to pick up a used Bridgeport mill in Easton, PA. Might just sit around and be amused by puppy Zoe, but while she is amusing, I can rarely sit around all day.
   / Good morning!!!! #161,783
got call from VFD to pull codes on Tender, found no active codes. They suspect still having algae issues in fuel system, they have been using algaecide but same problems with tender as last time.
Have you changed the fuel filters? If yes, then why not cut open the primary filter and see what is in it? What are the chances of water in the fuel? This is available in the 'States, too. force of habit, I went to .ca, but .com should have it too.Gasoila WF25 Regular Water Finding Paste, 2.5 oz Jar : Amazon.ca: Industrial & Scientific
   / Good morning!!!! #161,784
Three pulls, nothing. Fourth pull (and a little ether (hey, I have carpal tunnel - gimme a break)) fires right up
kilroy, it is your equipment AND your carpal tunnel. Do what you gotta do to get the job done.;)
   / Good morning!!!! #161,785
   / Good morning!!!! #161,786
I do give the equipment to do it on straight John Henry, but you reach a point where you just gotta make it happen. . .
   / Good morning!!!! #161,787
A Jolly good morning to all,
Presently 30F under clear skies, after an overnight low of 26, forecast high of 47, winds light.
Wife never came up with a 'honey do' list so it was a quiet and relaxing day. We shall see what today brings.
Ronjhall- What camera/lens are you using to get those fantastic shots?
Let's all be careful out there and have a good day.
   / Good morning!!!! #161,788
I sit all day long at work, which isn’t good.
I have spare run capacitors already sitting by my GEO units.
Watched a video yesterday where guy used car battery and 1000w inverter to run his gas furnace during power outage. Just add a battery minder and keep it for emergency use.
Won’t work for 240v motors.
   / Good morning!!!! #161,789
LS, how big is the UPS you bought for your pellet stove?
2012 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2012 MACK CHU613...
2019 GENIE S-45XC TELESCOPIC BOOM LIFT (A52709)
2019 GENIE S-45XC...
2013 CATERPILLAR 259B3 SKID STEER (A52709)
2013 CATERPILLAR...
Quick Coupler (A57149)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2023 MADJAX GENESIS 300 ELECTRIC CART (A57192)
2023 MADJAX...
