Networking gurus - Best method to delay network extenders on power reboot after outage
   / Networking gurus - Best method to delay network extenders on power reboot after outage #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My house requires network extenders to extend my wireless to the far corners where I have cameras. A problem arises when I get a power outage, the ISP's network extender (the ISP calls it SAT 1) comes up before the ISP's router, grabs the signal, then I cannot connect to the internet. The only solution the level 1 help desk could offer is to tell me to unplug SAT 1 until after the router is up.
That's fine but a pain when I'm there, but when I'm more than a few miles away it's a non-starter.
So I'd like to find some reliable method of delaying the extender's powerup for a few minutes. Any suggestions?
   / Networking gurus - Best method to delay network extenders on power reboot after outage #2
You're looking for a device that detects line power, waits a set amount of time, then energizes an outlet, correct?
   / Networking gurus - Best method to delay network extenders on power reboot after outage #3
I think it's called an on-delay timer. I haven't seen one that plugs into a 110V wall socket, but that doesn't mean they are not made. I have seen them that plug into socket bases in electrical cabinets. We used them extensively to control things at my last job.
Yup, that sounds like it.
Half of finding things is using the proper search term.
Thanks!
   / Networking gurus - Best method to delay network extenders on power reboot after outage #5
Why no just place a ups on the router?
   / Networking gurus - Best method to delay network extenders on power reboot after outage #7
This would probably work, but kinda pricey, about $70.
It's designed to come on 15 minutes after power is restored, to allow hot greenhouse lights to cool down before they attempt to power up after power is restored.
The router IS on an UPS, but there have been power outages that apparently the UPS drained.
But that might be a solution is to put all of the network equipment on UPS.
Looks good but in further research I found Supply House, which I use frequently, sells a Delay on make timer for < $10.
So I'll say problem solved.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #10
amazon.com/MSNSwitch-Internet-Enabled-Remote-Switch/dp/B081TKJJBS/ref=dp_prsubs_1?pd_rd_w=t03bL&content-id=amzn1.sym.ec3cee7c-6bd8-496a-8166-4fdb6d51cad1&pf_rd_p=ec3cee7c-6bd8-496a-8166-4fdb6d51cad1&pf_rd_r=SNPNZ3VV8X9QW01DF85K&pd_rd_wg=EQ7mB&pd_rd_r=356dea0c-2b90-453b-a15b-59e11019d914&pd_rd_i=B081TKJJBS&psc=1
This is what I use at a remote property I have.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #11
Yes, we could build up a box with wires and outlets and such and install that and it would work great.
I don't know your abilities, so I concentrated on a plug and play (pun intended) solution. :)
Show us the box when it's done.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #12
personally you have a network problem, extender's don't "steal" anything. the boot up sequence should not matter at all
   / Networking gurus - Best method to delay network extenders on power reboot after outage #13
I was wondering the same thing. A wifi extender shouldn't prevent the main router from connecting to the internet.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #14
Your use of the word "steal" is the first time in this conversation. ;)
He said "grabs the signal".
Unless all of the devices are permanently hard-coded, boot up sequence will matter, as whoever comes up first might be considered the main router by the ISP.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #15
FWIW...Anytime there is more than one router on the same network...The DHCP servers should be disabled on all but the primary router...this may or may not apply...
Yup
Some users may find that after the power outage or router’s rebooting, even after router’s internet is back and up running, client devices still get IP address from powerline extender, and cannot connect to the internet.
apparently they came out with a patch, which I have not installed yet.
   / Networking gurus - Best method to delay network extenders on power reboot after outage #17
I'm sorry. We do not offer technical support on that model unless all current updates and patches are installed. Please perform the update, and call back again when that is complete. Thank you.
Goodbye.
(ever get that message? :ROFLMAO: )
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2012 FORD F450 XL SUPER DUTY TRUCK (A59823)
2012 FORD F450 XL...
2015 Toro Sand Pro 5040 Bunker Rake (A59228)
2015 Toro Sand Pro...
John Deere 1025R (A53317)
John Deere 1025R...
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
2022 John Deere 1025R (A53317)
2022 John Deere...
