My Industrial Cabin Build
   / My Industrial Cabin Build #3,962
Thanks for the update, I am sure she is happy along with you guys !
   / My Industrial Cabin Build #3,965
Next time you install a cabinet, or anything similar... Make sure you shim behind the points you screw it to the wall. Otherwise it will not be solidly attached. For that bathroom laundry sink, you should have shimmed directly behind those 2 screws. I prefer the composite shims as they don't split like the cedar ones do. Once you have it screwed down and checked level and plumb, then use the multitool to cut off the shim sticking out. You can also use plywood or scraps of lumber the correct thickness. If you have a planer handy, you can make various thicknesses from 1x stock and write the thickness on them so you don't have to measure each time.
   / My Industrial Cabin Build #3,966
You have been so meticulous on your build. I know it is easy to be a Monday morning quarterback,but are are you going to fill in the gaps in the sheetrock around the water and waste pipes? (I know they are out of sight)
   / My Industrial Cabin Build #3,967
I was thinking, he forgot to put the escutcheons on, but I’m not sure I used them inside cabinets. It’s nice the back of cabinet is open. Most of mine has a back, and I had to cut holes for the pipes coming thru.
Yes. With foam.
   / My Industrial Cabin Build #3,970
We successfully completed the Mini split install.
Success! MR Cool 4th Gen DIY Mini Split
Congrats, I’m considering putting one in my garage.
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A55745)
2004 DRAGON 150...
2018 Nissan Titan 4x4 Crew Cab Pickup Truck (A53422)
2018 Nissan Titan...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
Paramount AP 2800 Leg Press Machine (A53425)
Paramount AP 2800...
2017 HITACHI ZX350LC EXCAVATOR (A53426)
2017 HITACHI...
2007 Ford Expedition EL Limited 4x4 SUV (A53424)
2007 Ford...
