Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,639
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
I run a kubota F 3680 on steep slopes and it does very well. Its not as fast as my Kubota zero turn, but it’s faster and more stable than a typical SCUT. My Kubota ZD331 is VERY stable on hills, but doesn’t get the traction to “match” its’ stability (if that makes sense). IOW, I will run out of traction before I run out of stability. The F-3680 will take you up or down or across and slope without fear of tipping.I know this has been discussed before but wanted to add a little more to the discussion. I currently have 3 Grasshopper mowers which I like a lot. I have a 325D, 725D, and a 900D. The 900D is by far my favorite as I have steep hills and the stability and traction is much better than the others. With that said there are a couple pond banks that even the 900D struggles a little so I have to go up certain areas backwards etc. The problem is the rear tires slide just a touch damaging the grass then erosion starts causing holes or small washed out areas on the dam. Would be nice to have a 4wheel steering mower with better traction. Right now I’m looking at Ventrac and the Kubota F series. Not sure which is better? Keep in mind I would use this mower in big fields to so mowing speed and comfort is important too.
Thanks
I heard the John Deere 74x mowers are also very stable. They have 4WD and 4WS models. I always wanted one, but felt like they needed a ROPS on them to protect the operator.
