Slowpoke Slim
Elite Member
- Joined
- Jan 6, 2017
- Messages
- 3,912
- Location
- Bismarck, ND
- Tractor
- Husqvarna YTH24V48 riding mower, Branson 3725CH
OP,
Depending on your field conditions, you may be fine running a 6ft on 25 (?)pto hp.
But if you have heavy, thick grass, you're going to have problems. It's not the brush and weeds that normally get you, they usually grow in thinner and farther apart. It's the thick grass, but by the time the grass gets really thick, you're having to slow down for lack of visibility also. You can't really see what's lurking in the thick grass, so you have to feel your way along.
I'm running a 6' cutter on 32 pto hp, and I almost never have to slow down from lugging the engine. But I find with visibility at zero, I have to play "blind man's bluff" with my front end loader and bucket. But I'm mowing other people's fields, not my own. So I normally have no idea what could be laying out there in the tall, thick grass. If you're only mowing at your own place, and you can get your field cleaned out from objects, then maybe you could mow faster?
But if you're mowing fields like this, you're not going to want to fly along anyway. I can't see the ground in front of my tractor, not even out of the bottom glass. My cab is just over 7' tall, and those weeds are over 8'. I'm pushing the weeds down with my bucket as I drive over them, going along at a fast walking speed. I wouldn't want to go any faster than that, just for finding objects like old tires, stacks of pallets, hunks of old fence, etc. I had no power issues here at all. That's 6' cutter on 32 pto hp though. -Edited to add- I'm also making full width passes with the cutter, not half passes.
