- Joined
- Aug 31, 2001
- Messages
- 65,856
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
Nice!I just checked ours, sort of a licorice taste...not bad.View attachment 775163
So you have 3 separate tanks? What's the advantage of that? AFAIK ours is just house-->tank-->leach field.Ours are 250 gallon verticals tiles. House, 1st 250, short pipe, 2nd 250, 20' of pipe, brick 1200 gallon brick beehive, 150-200' field tile (nobody's sure).
Yes, we have 3 separate tanks. Many single septic tanks have two chambers inside. Ours are just separate. As I understand it, the heavy solids settle out in the first one and are digested more before passing to the next. The liquids and lighter solids flow on to the 2nd one. The liquids pass on to either a dry well, or a leach field, where the liquids are supposed to seep into the ground through the bottom and holes in the sides of the dry well or holes in the leach field fingers.So you have 3 separate tanks? What's the advantage of that? AFAIK ours is just house-->tank-->leach field.
Have no idea when this was put in...PO (who'd lived here from the 60s) was deceased, granddaughters were handling the sale and they played dumb on any question I asked. I'd imagine modern systems are a lot more complicated.
A little Googling will prove you wrong, especially with car washes. Much less common with laundromats but some commercial laundries do re-use the rinse water from a previous load for wash water on the next.They don’t recycle water and neither to car wash’s
columbiatireauto.com
a 'sud saver'? I've heard that term from a friend who had oneYears ago, when I was a kid growing up, we had a machine that reused water, I think it was just the wash water. It took a pretty good sized wash tub to hold the water. I doubt a normal machine or laundermat does that any more.
