high gear paved road
/ high gear paved road #21
Only my 300 HP powershift can climb a hill and maintain 99% speed. My 180HP loses a bit in high range CVT. My 135HP loses considerable speed in high range CVT. My 126HP powershift loses a little speed. Maybe 1 MPH
/ high gear paved road #22
I've been associated with farm equipment for nearly 70 yrs. During that time I was employed by a JD dealer for 21 yrs with 13 of those yrs serving as dealer service manager. I rarely witnessed cast iron ballast removed from a tractor in order to lessen tractor weight once it was installed. YMMV
I do.
MUCH more easily done than liquid ballast.
/ high gear paved road #23
I do.
Liquid ballast never comes out unless violently caused flat tire (happened to me) or ownership change and new owner didnt want liquid.
Cast are still tough to remove, but doable.
/ high gear paved road #24
Bingo.
Yet another reason why I do not use liquid ballast.
Cast iron can be added/removed as need indicates.
So you stop and unbolt your wheel weights whenever you need to drive up a hill? Lol.
/ high gear paved road #25
I have a Kubota L4400 HST and had to drive it on pavement for 6 miles from repair shop. In High gear with full acceleration, it would not climb the hill until I moved to "medium" gear. Appreciate any input from anyone regarding this.
I'd say what you are describing is typical of every Ag, utility, and compact tractor I've ever driven. None of them would pull high gear on the road against even the slightest incline. It's true of our little 15 hp imports and also true of our 100+ hp JDs.
That's just how tractors tend to be geared and powered. Going slightly downhill - even very slightly downhill - is a whole different story. Then even the most underpowered ones will quickly get going too fast for their steering and brakes.
rScotty
/ high gear paved road #26
What are the weights of those tractors?
Weight and HP to the ground are really the only things that dictate how fast a machine can climb a hill. Double the power at the same weight, and you can climb twice as fast if gearing allows. Double the power AND double the weight......speeds are gonna be the same
/ high gear paved road #27
MX-270 is 24,000lbs
Massey 7495 is 16,000lbs
Challenger MT535B with loader is 16,000lbs
Kubota M-126X with loader is about 11,500lbs
/ high gear paved road #28
MX-270 is 24,000lbs
Hp/weight ratio when working a little math seems to verify your real world experience
/ high gear paved road #29
CVT’s, like hydrostatics give up speed in high range going up hills.
/ high gear paved road #30
Yeah, HST's aren't the greatest in high range. I borrowed my neighbors turbo 55hp gear utility tractor and it felt like a race car on the road! It also feels like a driving a racecar when unloading round bales off the wagon with its 8x8 unsynchronized transmission... grinding gears back and forth between reverse and forward got old pretty fast! My tractor is literally twice as fast doing that job.
/ high gear paved road #31
Just takes practice and brakes
/ high gear paved road #32
When I compare CVT and gear tractor options on 125-150 HP tractors, CVT models consistently pull more and make more drawbar HP than powershift versions. When equipped with a front suspension, the also have higher road speed.
Example:
/ high gear paved road #33
Why would that be? Seems like a powershift would be all mechanically connected whereas a CVT has a hydrostat in the works. Just asking.
/ high gear paved road #34
I know, I dont understand it either.
It works that way through a lot of the AGCO line.
Heres an AGCO house brand with same results, has different motor
Might be the Fendt CVT has some great pulling power?
The road speed being higher is probably because the CVT models have an available quad link front suspension that allows another 6-8 MPH because its got better handling. In other words, the power shift is mechanically limited for speed.
But the higher drawbar HP and pulling power of a CVT over the mechanical powershift I cannot explain.
/ high gear paved road #35
20ft 4-Door Shipping Container with Shelving (A64553)
20ft 4-Door...
2023 Ford Explorer SUV (A66738)
2023 Ford Explorer...
KUBOTA SVL97-2 SKID STEER (A64279)
KUBOTA SVL97-2...
DEERE 410J Engine (A68134)
DEERE 410J Engine...
2012 CHEVROLET CAPRICE POLICE CAR (A66091)
2012 CHEVROLET...
2017 CATERPILLAR 926M WHEEL LOADER (A65056)
2017 CATERPILLAR...
