Repair Common Kioti Mechanical Injection Pump Failure
   / Repair Common Kioti Mechanical Injection Pump Failure #41
A flashlight will be your friend when trying to reassemble it. I thought I had mine all lined up when I reinstalled the gears and put everything back together as the tractor started right up but then as soon as I tried to drive out of my shed it started to run like crap and lots of black smoke. Parked it, disassembled it all and then used a flashlight while reassembling to see that the marks were all aligned this time, reinstalled everything and bingo, runs great.
ETA: The IP removal and DIY from neches was huge help as well as this forum.
   / Repair Common Kioti Mechanical Injection Pump Failure #42
Awesome , I can't see anything on my current gears. The plungers will go in 2 ways as well, what is the correct position to reinstall them.? I am pretty sure I have them laid out correctly but since it is such a "fun " job I want to try and do it only once. Thank you .
   / Repair Common Kioti Mechanical Injection Pump Failure #43
I seen that post and it pointed me in the right direction as I didn't really want to rip the pump apart without some decent research. He covered everything in his post except the timing , my rack was stuck and of course the last gear I removed was the one broken so placement of the rack to gears and plunger direction may not be correct for install. Thank you
   / Repair Common Kioti Mechanical Injection Pump Failure #44
Maybe THIS thread can help. It has been a while since I did mine and I just remember going slow and keeping all the parts for each gear/plunger/spring/sleeve together.
ETA: you do have a shop manual to help you along right? If not IM me as I believe I have an electronic copy of it saved I can send you.
   / Repair Common Kioti Mechanical Injection Pump Failure #45
   / Repair Common Kioti Mechanical Injection Pump Failure #46
No manual, these are pretty basic to work on it is just the injection pump system that can give issues on anything and need specific info that varies from one to the other. A friend works at the local Kioti dealer and his books do not show anything other than replacement of the pump. Anything I have run into mechanically that I don't have books for I use the net and it has treated me well. I have a 6.0 diesel with 400k on it so fear is not an issue for me . Lol If your manual has the injection pump rebuild info in it then I would certainly appreciate and help it can give me. Thanks for the reply . 👍
   / Repair Common Kioti Mechanical Injection Pump Failure #47
Not sure they count as pump rebuild info but they do show the gears, plunger and somewhat the orientation.
ETA: removed pics of manual due to copy right infringement.
   / Repair Common Kioti Mechanical Injection Pump Failure #48
I got the the new gears, they have a timing mark on them that lines up with the lines on the control rack. The plunger goes in with the slot facing to the left. I would suggest moving the Teflon bushing in the pump where the solenoid goes a little to the right to install the injection pump just to male sure it does not contact the control rack during installation. Once the pump and the return spring on the left are installed you can use a small screw driver to make sure the rack moves freely and there is spring pressure on it by inserting the screwdriver into the hole for the solenoid switch. Once everything is re installed , bleed the system of air and then start it .
Thanks you to the original poster and all who replied, you saved me and others alot of money The cost for this repair at the dealer would be around $3000 Canadian (2200 US) , my cost was $91 for the gears and shipping and roughly 3 hrs easy labour.
   / Repair Common Kioti Mechanical Injection Pump Failure #49
After reviewing this forum and a few other websites, I finally found the information I needed to repair my Kioti CK25 Fuel Injection Pump. It was the usual issue, the gear teeth were broken and the rack was stuck.
I ordered the parts from Moose Diesel. The 3 gears were less than $100. I would call them first to make sure the parts are in stock. Here's the link:
A big thank you to 2881Neches for the excellent tutorial and photos that has been around for some time now and I'm sure many people have benefitted from.
Here is also a youtube video by tractors&marine MECHANIC that does a very good job of demonstrating how to take a 3 cylinder Zexel (or very similar) injection pump apart and put it back together.
It took about a week to get the parts and I spent about 3 days researching the issue and how to repair it, but it only took about 15 minutes to actually take the pump apart and put it back together with the new gears. Just make sure the rack that turns the gears slides back and forth freely before putting the IP back in the tractor. You might have to take some emory cloth to it like I did and smooth out any scratches or gouges that were made by the broken gear teeth.
   / Repair Common Kioti Mechanical Injection Pump Failure #50
Video does not show the orientation of the plunger. It can go either way (180 degs.) and it will make a difference. If wrong it could allow a flow of fuel even in the off position. RUN AWAY ENGINE!!!
AG-FAB PULL TYPE SWEEPER (A58374)
AG-FAB PULL TYPE...
Air Compressor (New/Unused) (A59225)
Air Compressor...
2298 (A58376)
2298 (A58376)
2018 Takeuchi TL10V2 Track Skid Steer, S/N 410002082, Kubota Diesel Engine, Joy Stick Operating (A59076)
2018 Takeuchi...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
