Leaking steering joint
/ Leaking steering joint #1
YanmarMatt
Yanmar ym1510d
Anyone have an idea of what my issue might be here? I have a ym1510d. I used it recently to move some dirt and rock. After I parked it in the garage I noticed there was some oil on the front tire. See the picture. I am hopeful that’s a simple gasket to replace and relatively easy to access and then relatively easy to put more oil in. Does anyone know what component I might be looking for or what the issue I am looking at might be?
/ Leaking steering joint #2
I read something on hoye regarding gear oil. Am I good to use 90wt or 80/90 or any similar gear oil when I refill?
/ Leaking steering joint #5
You can lift the front end and check for play in the pivot assembly or if any roughness can be detected in the bearings. If if feels ok you can just go to using a light grease (0 or 00) in the front end. No more nuisance leaks.
/ Leaking steering joint #6
80W90
90W
75W80 synthetic
Stick with GL-4 as the wear protection is higher than the eco-friendly GL-5 with less.
2019 Chevrolet Tahoe SUV (A61574)
2019 Chevrolet...
2014 John Deere 350G Hydraulic Excavator (A64194)
2014 John Deere...
2019 JCB 2TS-7T High Flow Compact Track Loader Skid Steer (A61572)
2019 JCB 2TS-7T...
2022 EZ-GO ELITE...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
John Deere 6125R (A60462)
John Deere 6125R...
