Trimming around chain link fence.
/ Trimming around chain link fence. #1
dj1701
East Concord, NY
John Deere 4320, Kubota BX2680
Hi all,
Anyone ever found an easy way to trim around chain link fence? It chews up my trimmer line and I just hate doing it. I wanted to make the dog area bigger, but the thought of trimming it gives me pause.
Dave
/ Trimming around chain link fence. #3
I sunk railroad ties, half posts and 4X4's around the perimeter of the dog run. Inside and out. Had some dogs that just would not stay put.
The benefit was - I was no longer hitting chain link, trimming the area up.
/ Trimming around chain link fence. #4
Some people lay a concrete mow strip under where the fence will be. The required width would be determined by how close your mower can cut to the fence.
/ Trimming around chain link fence. #7
/ Trimming around chain link fence. #8
Hi all,
Dave
Don't trim it. Spray it.
/ Trimming around chain link fence. #9
Project Farm (YouTube) did a video comparing trimmer strings. Round string did much better against hard surfaces than string with edges.
I haven't tried round string yet, as I have a lot of edged string to use up. I might just buy a small roll to see if it is better with chain link.
/ Trimming around chain link fence. #10
Spray it.
This is my process for the posts of several thousand feet of pvc horse fencing. I did not want to damage the pvc posts with the trimmer line. Spraying once or maybe twice a season works extremely well.
/ Trimming around chain link fence. #11
Spray vinegar along the fence line.
I have two weed whipper brush cutters - a Husqvarna with blade for the rough areas (not near the fence, it will destroy the fence); and an Echo trimmer with 3 plastic prongs (way more durable than the string) and when they break it is a simple replacing the prong. I would still stay a foot or so away from the fence. The dog marking territory probably also plays a role.
Put a low box garden bed, along the fence line inside the dog area 12 - 18 inches or so.
/ Trimming around chain link fence. #12
Get a string head to hold large strings. Something that holds .155 or larger. Easy to use and strong enought to take tree shoots out. I'd be done with this job in 10 minutes.
/ Trimming around chain link fence. #13
Install the fence 1" above the ground.
/ Trimming around chain link fence. #15
Here’s my solution, I have just over 1 acre fenced for my dogs. I too didn’t like trimming the fence line, 2X8 treated drilled out to go over the fence posts, and then a bottom bar to tie the fence to allows me to mow right up to the fence without a lot of trimming, and keeps the dogs from digging and pushing under the fence.
/ Trimming around chain link fence. #16
Here’s my solution, I have just over 1 acre fenced for my dogs. I too didn’t like trimming the fence line, 2X8 treated drilled out to go over the fence posts, and then a bottom bar to tie the fence to allows me to mow right up to the fence without a lot of trimming, and keeps the dogs from digging and pushing under the fence.View attachment 773579
That doesn't seem very practical if you've got a couple miles of fence. I'll stick with glyphosate.
/ Trimming around chain link fence. #17
Yeah, I used railroad ties, half posts and 4x4's.
I had a demon dog, he was big, his jaw power and teeth basically wore out the chain link. He just kept tugging at it until it unraveled.
At least he did not get under the fence. I sunk field fence under all the wood.
He just wanted out and to always be with someone.
