MF 2660 Perkins Smoke
/ MF 2660 Perkins Smoke #1
JWR
Elite Member
So MD / WV
MF 2660 LP, 3 Kubota B2150, Kubota BX2200, MH Pacer, Gravely 5660, etc.
My MF 2660 has about 550 hrs or slightly less on it. 2010 model bought in April 2011. Never ever a minute's trouble with that Perkins. Probably the most reliable thing about the tractor... Anyway on 11/27/22 at about 38 degrees outside air temp I started it up with no problem and went about using it for 1/2 hr grapple working some limbs. Warmed into the 50's while working. Then I moved to a different field to do final bush hogging of meadows before winter. That's when the smoke started. Heavily smoking blue/white smoke for several hundred feet of downhill travel. Could find nothing wrong. Oil at full mark. Temp normal. Running smooth. No warning lights on or blinking or momentary. Same as always except for the smoke. When smoking it was heavy not just a hint but a LOT of smoke. Nothing like I saw one time when a diesel was burning crankcase oil (black cloud about like a plane crash) -- not at all similar. During the next 90 minutes of work cutting heavy wet grass and weeds everything ran totally normal. No issues but once in a while a period of smoking. ALWAYS GOING DOWNHILL or just after downhill travel. Never smoked going uphill.
Background: The fuel tank was down low to probably 4 or 5 gal when I added one 5 gal can of red dyed off-road diesel the night before the smoking started. That fuel was from a high volume regional supplier at their terminal and had sat in the can about 1 month. The can was "clean" in that it is never used for anything but diesel and kept closed in a garage. Next morning, the day of the smoking, I added one more fresh can of fuel (not off-road, just purchased from a truck stop that morning) which brought the gauge up to a little more than half full.
Note also that I had my 2660 modified in 2011 when new because the #$%^& thing would not climb a 45% slope with 1/3 of a tank of fuel (!) Stalled. Starved for fuel. The dealer put a T with stop valves in the legs such that one pickup was in the back and one in the front of the tank. That solved the hill-climb starvation of fuel issue.
[I was cussing mad about that and a dozen other issues at the time in a brand new tractor right off the showroom floor. Another long story.]
Now, all that said, my theory is that this smoking is/was a fuel issue. It only happened going downhill or just long enough after downhill for the fuel to get picked up and in to the injectors. It cannot be crankcase oil related (burning that would be coal black smoke.) I know of no path for hydraulic oil to get into the combustion. Total cumulative smoking time out of a 2 to 2.5 hour running time I estimate was a few minutes, not just a few seconds.
What say you world of experienced diesel operators ? Why was is it smoking ? [
I say "was" because after a couple hours operation there was no more heavy smoking but 1 or 2 times I did notice a very light smoking for a few seconds... obviously not staring at the exhaust for 2 hours. When it was smoking heavily it got your attention without looking at the exhaust.]
/ MF 2660 Perkins Smoke #2
Here's a Wild, Wild WAG-- could you have a failed valve stem seal (or a crack or some other means) near the front of the engine, or in a location where run-off valve train lube oil could pool and/or run into the intake passages in the head, thereby entering the combustion chamber? Altho smoke from burning lube-oil would generally be more blue than black.
If you throttled down to idle during one of these episodes, do you think all cylinders are excessively smoking equally, or ate there distinct puffs, indicating only one cylinder is the culprit?
Did you or could you notice an increase in power, coming from the extra "fuel"? On older engines (before controlled emissions) there was a "blow-by" tube under the engine to vent crankcase fumes out to atmosphere. It would be interesting to see if the amount of blow-by "fog" decreased during these episodes.
Could engine oil pool in the air intake system somehow to feed oil or fumes into the engine? I'm thinking of the old EGR systems on gas engines. There are engines that have a system to "scavenge" crankcase fumes and route them to the air intake so they burn (as fuel) instead of venting them to the atmosphere.
I suppose if you burned enough engine oil, it would show up as low oil on the dipstick.
The old 2-cycle Detroit Diesels would actually "run away" when seals in the blower or turbo would fail and the engine would suck in and run on engine oil. If I recall correctly, they were equipped with an emergency flapper that could be deployed to block the air intake, to snub the engine in such a situation. If left unchecked, the engine would over-rev to the point of self-destruction, IE--blow up!
/ MF 2660 Perkins Smoke #3
I say it just sucked some air into the system through one pickup or the other since you mentioned the T on the pickup lines. Once the air was cleared through the system the engine went back to operating normally.
Sounds like a poorly designed fuel tank without enough slope on the bottom to take hills and slopes into account.
/ MF 2660 Perkins Smoke #4
If your engine intake system has a “THERMO-START” ..
Check it for proper operation.
Unhook the fuel feed line and cap it..
Good luck
Good luck
Do not know what that is. I will need to look into it. Hold that thought...
Would sucking air instead of fuel produce blueish white smoke ? There was no effect on power that I could detect, though going down hill it would not show. A few bursts of smoke did happen just after a downhill but I never felt any interruption of power output. I would have felt it then after the downhill.
/ MF 2660 Perkins Smoke #7
If it does have that system.. it’ll be screwed into the intake manifold where the rubber ends and aluminum starts..
There will be a single wire and a tube for the fuel to enter the intake.
No, lube oil in a diesel, if burned, puts out some really black smoke, not blueish.
No distinct puffs. It ran the entire time like nothing ever happened. I did throttle down to idle AND up to higher than normal operating rpm during the smoking and could see no change. No missing, no stumble, no change in the smoking.
No. No change in power output.
Not sure about fumes but EGR systems on a VW diesel can put lube oil in the intake and the result is black smoke out the rear -- big time!
No apparent engine oil usage. Checked it after this incident and had checked it a month ago. Right at the full mark, no change.
Amen to that ! Tell me about it! I had a VW diesel start sucking engine oil from the crankcase due to excessive blowby in it's old age. It fogged the entire highway with sooty black smoke for 1/4 mile until I finally figured out what was happening. Key would not shut it down of course and I had to put it in high gear and use the brakes to stall the engine. Thank goodness it was a stick and not automatic! That happens you will never forget it. Using air intake blockage is about the ONLY solution if it had been an automatic. And that never occurred to me so I would have lost the engine if it had been automatic.
/ MF 2660 Perkins Smoke #9
Lol.!!!! Run aways are funny.. it WASNT the FIRST TIME tho..
I love watching people freak out..
I’ve had the pleasure of watching SEVERAL.. & putting out most..
  • Good Post
Reactions: JWR
/ MF 2660 Perkins Smoke #10
Sourced from the web:
-Continuous “light” white smoke
To run correctly, a diesel engine needs precise timing of the injector pump and proper pressure. Any decrease in the pressure or delay in delivering the fuel to the combustion chamber will cause incomplete combustion, and you will have white smoke.
This is a steady stream of lighter white smoke. It can even be random but often “puff.” Some likely causes include,
A clogged fuel filter
Low pressure in the fuel pump (Air in the fuel)
Faulty or damaged injectors
Enough air to cause smoke but not enough to interrupt power.
/ MF 2660 Perkins Smoke #11
Basically it’s unburnt fuel..
U can tell by the smell and it burns your eyes.
See orig post: I was blaming it on fuel from one or the other of the two dissimilar cans I had added just prior to this incident. The first can full (red dyed off road) being lower in the tank than the second can (plain on-road filling station diesel) added that morning. The T pickup in the tank maybe getting mostly fuel from one of the two cans while going downhill??? Far fetched? You guys don't seem to think it was a recently added fuel issue ?
/ MF 2660 Perkins Smoke #13
If you think you burnt enough fuel out of what you put in. I'm still leaning it to be an air issue pulling from one of the two pickups in the tank. In this case when the fuel flows forward going downhill, it has to switch to the front pickup and that could let it suck a small amount of air into the rear pickup. Before pulling from the front pickup entirely... JMO..
Even though they claimed it wouldn't at the dealer... I call hogwash...
Has this happened before when low on fuel downhill? Or just this time? Or have you taken this hill before full on fuel and it not happened?
Experiment... Fill completely full of fuel and roll that same hill downwards multiple times.. if it doesn't happen then you have an answer. If it does you can look elsewhere for the problem. I find eliminating possible issues the easiest when problem solving not just back and forth chasing possibilities.
It matters not what a dealer said 11 years ago. That's when the fuel pickup mod was done on a then-new tractor. It has NEVER had this smoking issue at ay time in the last 11 years and 550 hours of operation. [And that has included far steeper up and downhill utilization than this incident, many times.]
I've gone down these hill sections 15 or 20 times (and similar ones 100 times) and never any smoking.
Understand that logic, but keep in mind that the smoke issue was gone before the end of the 2 to 2.5 hour operating period on 11/29/22. I do not even know (yet) whether I can reproduce it . It does not help that I am 330 miles from my farm and only there once a month.
I can detect no loss of power or stumble or missing when it is smoking but then that was almost all going downhill. The few times it did it on the level was just AFTER a downhill and I would certainly have known if it was missing or chugging or stumbling.
/ MF 2660 Perkins Smoke #15
certain coolants will put out a bluish/white smoke if gets into or hits exhaust.how close is your overflow tank to the exhaust manifold/exhaust end?
change in orientation as well as hot bottle can open small cracks that close up when cooler temp coolant in tank.
only takes a few drops to cause this so bottle may not look like its losing coolant.
I'll check all the possible coolant paths to the intake BUT this incident had the smoke coming out of the exhaust pipe, not from the manifold or anywhere else.
/ MF 2660 Perkins Smoke #17
I missed the fact the fact this had vertical exhaust, not sure where air intake is one that in relation to coolant system
No, I'm sorry, the exhaust is horizontal out the back underneath because this is a low-profile version. Comes out right beside the lower right lift arm sway bar. The air intake is up front, in front of the radiator in a fairly large open area behind the front grille.
/ MF 2660 Perkins Smoke #19
LOL wow I didn't know about low profile.
the only reason I am thinking coolant issue is because of this:
blue/white smoke
fuel issue will NOT show white.
white out exhaust is coolant.
how positive are you on these colors?
with that being the low profile rear exhaust I suspect no way to safely capture it on video while driving w/o killing yourself.
all I can say is diagnosing an issue ain't worth killing yourself over :)
Yeah, pretty much impossible to capture on video. I may very well be over reacting since this only happened that one day and by the end of a 2.5 hr operating period it was long gone. The intense smoking period only lasted while traveling 300-400ft through a meadow and then the rest of the incident were shorter bursts lasting maybe 50-75 feet and medium ground speeds.
It was not pure white, that's for sure. Light blueish cast to it. I've seen some tractors and other diesel engines put out very plain white smoke and this was not like that. Some definite blue to it. Of course I am anxious to get back up there next trip and run it a lot more.
I had one very experienced, retired, former Regional Rep for Deere and then later for Kubota for many years say that it COULD be a leaking head gasket OR a leaky set of seals at the intercooler for the turbocharger. I don't like to think that but could be I suppose. Only 550 hrs. never overheated, etc. First priority is to check the radiator coolant level as soon as I can get up there.
New/Unused CFG Industrial QK16R Mini Excavator (A65583)
New/Unused CFG...
ELECTRIC MOTORS, ELECTRIC PUMP (A64276)
ELECTRIC MOTORS...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
2022 EZ-GO ELITE...
NEW Wolverine ADB-13-1218R, Skid Steer Auger (A62679)
NEW Wolverine...
2020 Cushman Hauler 1200X Gas Utility Cart (A64553)
2020 Cushman...
