Front loader level indicator
/ Front loader level indicator #1
Rcsask
Saskatchewan
none
I just got my tractor and the level Indicator is confusing. Unless the dealer set it up wrong but when it's flush the bucked is digging in still. How does everyone else have there? Really wish there was a work around to get something that kubota uses where it falls into the bend part seems much easier to see from the cab.
/ Front loader level indicator #2
I'm sure someone will be along to answer your question. Meanwhile I happened to run across this short video reminding me of a bucket level indicator:
/ Front loader level indicator #3
It should be adjustable, set it up however you like. I have mine on the cab tractor set so it is about and inch off the ground because that is the tractor I use to move snow with and don't want it to dig into the gravel.
So it's flush with the top of the orange tube part?
/ Front loader level indicator #5
I just set my bucket flat, then cut my level indictor rod so its flush with the tube.
/ Front loader level indicator #6
I can easily see the flat top of my bucket so I don't use the level indicator.
I have seen operators adjust the rod (or cut) so it's flush with the tube, depending on design. Paint marks or tape also work.
/ Front loader level indicator #7
No idea how your dealer set it up or if they did. Also no idea what your specific indicator looks like....but...
Park it on flat level surface and make the bucket level. Now what does the indicator look like? Either make a mental note where level is...or adjust?modify the indicator to your liking. But even a level bucket can still dig in, or not dig at all....unless you are on perfectly flat land.
/ Front loader level indicator #8
I don't worry about mine. At all. It's off by a little bit so I just make a mental note and continue to march
If you're on a slight grade in either direction, it isn't right no matter what. So you can jump through hoops, cut this, cut that, mark this and that, move attachment points all over the place and --
It still isn't gonna be perfect.
Then, if you do happen to get it set just right for your bucket (good luck) when you put your forks on, it ain't right.
Then your grapple; and it's got a different understanding of what's level.
You can do what you want to. It's your tractor but I liken fiddle-fartin' with the level indicator to re-arranging the deck chairs on the Titanic.
Just my .02c and worth even less :)
Congratulations on your new tractor and tell us what you've got by filling in your info.
Welcome to TBN. It is the most helpful tractor site on the 'net
/ Front loader level indicator #9
I like my indicator to be correct. Since it is a rod going through a hole in a plate. I found level and painted one color above and another below. Easy enough to do and use.
/ Front loader level indicator #10
So do I.
I have my indicator cut dead on when the rod is flush with the tube.
And the indicator being correct does help by a lot IMO.
/ Front loader level indicator #11
Very seldom use level indicator just watch bucket.
/ Front loader level indicator #12
This one is everything I need. When it is level the bucket is level to the ground, at ANY elevation. If I have forks fie feet of the ground and this is level, the forks are level.
BTW, this is NOT my bucket but an example. I am on my second bucket after 6400 hours on the L2550DT... :)
/ Front loader level indicator #13
I think the larger your tractor the more you will use a bucket level indicator. I too can see my bucket from all of my tractors, however, it is not always easy to perceive if the bucket is level even seeing it. The indicator takes the guesswork out of it. I have one tractor that does not have it and I have used it for a couple years and still have a hard time knowing when the bucket is level. If I keep it, I will be buying an indicator to put on it.
As others have said, you have to find what level is on your tractor and make a mental note or tape or paint etc. so you know where you are at. After getting used to the indicator, I can't imagine not using one.
2011 CARGO CRAFT PUMP CONTROL TRAILER (A67714)
2011 CARGO CRAFT...
2016 Ford Explorer AWD SUV (A66738)
2016 Ford Explorer...
2018 GENERAC MOBILE PRODUCTS MLT6S (A68842)
2018 GENERAC...
2015 ARMOR LITE TRAILER (A67714)
2015 ARMOR LITE...
2018 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TRACTOR (A69167)
2018 INTERNATIONAL...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
