Ym loader install
/ Ym loader install #1
bennyhill
Member
yanmar 2210b
I ve seen video's on YM tractor loaders that attach to the end of the railing cass to the front bumper.
Then I've seen them say you need to put a new cass under the tractor from front to the back to make it strong enough and not break the tractor in half.
I u understand the reason for the new cass, but I see them with out the new or full cass.?
/ Ym loader install #2
I welded rails from the back axle to the front loader mount on an FX335 years ago.
It made it a long stronger, just be careful where you attach the the rails.
It also kept a lot of branches out that would of come up and damaged the underside.
I noticed that my Branson tractor has the rails from the factory.
/ Ym loader install #3
Thread with photos. Dealer-installed loader on a US Yanmar.
I've never read here of a Yanmar breaking in half at the bell housing but I've seen photos of other brands that did.
388519-dscn4220r-jpg.20688
/ Ym loader install
I read somewhere, two flat pieces steel from front to back, my question is how would you attach to axle?
And then to the front bumper?
/ Ym loader install
It's hard for me to see that. But I will study it. Has anyone ever heard of westondorf mfg , on you tube
Rear loader, with or without hydraulics.
1,900.00 before shipping!
Like some kind of sissior lift..
/ Ym loader install #7
Like some kind of scissor lift..
YES, I've looked it over several times.
Back around 2010, a REL would cost $700 with hydraulic controls for the top-link! The price has more than doubled since then.
The bucket is only $300. It's the Swisher ATV bucket with added 3PT brackets.
And can be adapted for front use too, just the lift isn't as high as a real FEL.
The last I looked Home Depot sells the Swisher bucket on special order. :)
/ Ym loader install
The ones I looked at dis not have hydro like the ones on top.
And you didn't have a trip arm to dump...
And with your pics, that loader is way out there lol
Counter weight Big Time😝
/ Ym loader install #9
On the bigger tractor (1st one) the REL isn't too far out. The 1st one does have the top-link hydraulic dump controls.
If you don't go with a hydraulic top-link, an electric linear actuator would do the job too. Some are fully capable up to 4,000-lbs with infinite travel between end-stops. A double throw action switch to tap power to tilt or retract the bucket is all you would need. It would be a poorman's Yanmar UFO control of sorts.
The smaller lawn tractors can get by with the trip-lever action.
Now here's another IDEA.
Use the swisher bucket with the trip arm. Then buy the Harbor Freight 2,500-lbs tow winch. Place the cable at the bucket trip area. The winch has a remote control too. thus, the REL would be fully functional for way less than what anyone else sells today. :)
This is where mine sits on the back of the Yanmar.
/ Ym loader install
WOW 1,000.00 for a bucket ROFL
I'm really thinking about making one now. From watching video's on youtube, I couldn't lay my eyes on how they are making it dump?
But still right now is hate to buy anything much less Steel !
Makes me thankful for my chickens lol
/ Ym loader install #11
Really? The price jumped that high? It was $299 at Home Depot in November 2019 the last I looked. WOW, it's $890 now. Crap.
Northern Tool right now has the best price of $850. zoinks.
/ Ym loader install #12
If you don't weld, then this type of bucket bolted together would work with angle steel to brace the seams everywhere.
2-in-1 Modular Plow bucket technical info
Material: Powder coated steelBucket
Working width:1280 mm / 50.4 in
Bucket Capacity:108 l / 28.5 gal
Bucket Load Capacity:50 kg / 110.2 lb
Plow working width:1280 mm / 50.4 in (with extensions 1600 mm / 63 in)
Plow working height:360 mm / 14,1 in
Adapter:Requires a front-mount adapter available with
a model-specific mounting kit
They are pricer than Swisher, BUT, looking at their product images a person can make a bucket at home for so much LESS. So, look at the link below for IDEAS.
/ Ym loader install #13
This one sold for a mere $121 in 2017. The price has increase 9X since then.
purplewave.com/auction/170510/item/CC9180/Swisher-ATV_and_Utility_Vehicles-ATV-Missouri
/ Ym loader install #14
My neighbor was given some small CAT-0 attachments for his Ford 1500 SCUT. In the bunch was a home-made 55-gallon metal drum with mounting flanges. It was used to scrap the soil to pick up dirt and rocks. It resembled the image below. Howbeit a bit more crude. I just wonder if a 55-gallon metal barrel c
I just wonder if a 55-gallon metal barrel cut like a Pacman shape could be used as a 'general' use bucket. The cutting lip would have to have a reinforcement plate. Wow, i'm not the only one who thought of this, people have already made them.
I can get used metal 55-gallon drums for free all around here. Nobody wants them. Yet, the blue plastic type sell up to $20 each.
/ Ym loader install
Yes I've seen those.
At the least they wouldn't last 1hour.
Here in south carolina metal drums are running 35 and up, to burn in.
The plastic ones 25 and up
I just saw a guy make a rear loader/no hydro on YT, looked like a lot of steel lol he did a good job, had a nice shop.
Not as big as mine cuz mine is the hole out side ROFL
/ Ym loader install
That would prob make a good snow plow... I wouldn't be worried about snow down south lol
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
TAKEUCHI TL12V2 SKID STEER (A65053)
TAKEUCHI TL12V2...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2004 AGCO Gleaner 3000 Corn Header (A61307)
2004 AGCO Gleaner...
2019 Peterbilt 567 Cab and Chassis Truck, VIN # 1NPCX7TXXKD273140 (A65563)
2019 Peterbilt 567...
2022 New Holland Boomer 45 (A64126)
2022 New Holland...
