Gravel names
/ Gravel names #1
repete
SW Washington
L2550DT IH584-4WD
DKMC posted about the names of gravel types in your regions.
In the PNW (to the best of my knowledge), we go by an inch dimension. 5/8" minus is any size gravel that will pass through a 5/8" screen. That would include any fines less than 5/8". 1 1/4" minus is the same, anything that would pass through a 1 1/4" screen.
What would this 5/8- be called in your neck of the woods?
/ Gravel names #2
In Indiana's neck of the woods gravel is called a number that is meaningless. (n)
/ Gravel names #3
In SE TN/NW GA I have heard the 3/4" minus, 1 1/4" minus etc. Which makes total sense. But they also have something called 57's, not sure where they came up with that. And crusher run, which I think is pretty ubiquitous.
/ Gravel names #4
I'm employed by an aggregate company, for about 6 months now, and the numbers STILL don't make sense to me... but I'm starting to catch on. I guess my job as an electrician makes it more important that I keep the conveyors running than know what number rock is on it!
57's are about one inch, normally washed. 8's are half inch, washed. 9's are 1/4", washed. Bigger stuff is 4's at about 2", 2's is bigger, about 3.5"... then the RipRap classes, D-rock is the smallest, at about 4-6", then C-rock, B-rock in the middle with A-rock being boulders 24"- up.
/ Gravel names #5
Obviously there are regional colloquial terms that often have no real reference to the size of the aggregate...
Technically most quarries/rock crushers reference their gravel terms/sizes by the last name/size of the sieve screens installed on the crusher...
On a side note...when the last sieve is standard 1.5"...everything that passes through is called "crusher run"
/ Gravel names #6
In Illinois it also goes by random numbers which were assigned by our DOT years ago. For example CA6 is gravel with fines. The CA stands for course aggregate. CA7 is the same as CA6 but no fines. Then you get into the FA, which if fine aggregate, more or less different kinds of sand.
/ Gravel names #7
This is what the local quarry calls theirs.
/ Gravel names #9
Our area uses the same definition as the ops, which makes a lot more sense and is more easily understood that cryptic #10, #57, and so on used in other parts of the country. But even at that I find one supplier's 5/8 minus can be totally different stuff than another's. Both may pass nothing larger than 5/8 inch across a grading screen, but both the size and shape distribution of different sources for 5/8 minus can vary drastically. For driveways and I much prefer flake-ish shaped crushed rocks versus more roundish crushed rock as they don't sink into the under lying soil as easily.
/ Gravel names #10
For me, it is mind-boggling to figure out. There are many different quarries and grades + pet names depending on who hauls. Add to that, the rock can have (depending on where it is mined) different binding materials included from sand to clay to whatever. Luckily, a guy I use a lot is a few miles down the road and stockpiles some material I can touchy-feely before buying. Otherwise, it is somewhat of a crap shoot. The largest mine, especially for driveway material is a LONG way off and they do not allow people to drive in and look. It is commercial only and even driving close to the place is hazardous to vehicles finish with rock everywhere on the roads.
I envy anyone who lives in an area they can figure it out !
/ Gravel names #11
Around here crushed limestone and recycled asphalt is commonly used for driveways. Gravel is more of a decorative stone.
/ Gravel names #12
All our quarries use 3/4" as the cut off up here, not 5/8. 3/4"-MINUS would mean everything that passes through the 3/4" screen, but you can get it with fines (21A) or clean/washed.
Never seen "57" up here. But I like those prices from kentucky! Ouch, our gravel is all $30+/ton up here. RIP OFF!
/ Gravel names #14
If we did make things silly and complicated our country would be as boring as some foreign countrys over the pond😁
/ Gravel names #15
I always ask for gravel that meets State Highway Specifications, as that was always what we had to use for electrical construction jobs under roadways. Compacts evenly (90% compaction was achieved with less work) and makes a better road base.
I thought it was odd that there was not a national standard on naming rock size.
/ Gravel names #16
Here you can get any size you want. From lime dust to boulders. There is even variations in the groups to choose from that isnt listed. I get the DGA with more dust to build a pad versus the hiway grade DGA.
Their trash rock comes in two grades, the fines which is dust and granules and the large which can have very large rocks in it.
No restrictions on who can purchase. You will see everything from a Subaru with a trailer up to triaxles.
/ Gravel names #17
Seems like it changes hauler to hauler around here. Some places use the size minus and some use a "number" system....
/ Gravel names #18
DGA??
2021 Kawasaki Teryx KRX 1000 SE (A62679)
2021 Kawasaki...
2016 Chevrolet Silverado 4x4 Crew Cab Pickup Truck (A64194)
2016 Chevrolet...
Mayrath 10 x 63 Portable Swing-away Auger (A66408)
Mayrath 10 x 63...
WOLVERINE SKID STEER TO 3 POINT ADAPTOR PLATE (A64553)
WOLVERINE SKID...
2016 Ford Explorer AWD SUV (A64557)
2016 Ford Explorer...
1991 Ford F600 Fuel Truck, VIN # 1FDNK64P0MVA37029 (A65563)
1991 Ford F600...
