Tip of the day.
   / Tip of the day. #201
When I put water in the golf cart batteries there are 18 or 24 1 inch holes that need a controlled fill. I use an awl to poke a hole in the cap of many plastic water bottles (16oz) and just point and squeeze. Using a flashlight with the other hand helps illuminate the water level in the hole. This makes quick and easy work of the task.
With the price of bottled water, this is cheaper and more convenient.
   / Tip of the day. #202
I put racket straps in gallon ziplock
   / Tip of the day. #206
I worry that straightening up my strap mess will lead to an addiction for neatness and order in all things.
They are cool ideas though. What the hell Im going for it. Ya know what they say. First ones free.
I too use appropriately sized plastic bags for my ratchet straps. I've lots of straps. Some of those 4" x 27' require large bags, the little 1"x10' will often fit in a ziploc type sandwich bag.
   / Tip of the day. #207
I just use the big box store cheap bags. Even double bag them to prevent blowouts. Jon
   / Tip of the day. #208
I use 50 cal ammo cans for small straps and 40 MM ammo cans for the big ones, all tied with those tiny bungees with the ball. Water tight and all contained. Grab the can and go or usually already in the cross box.
   / Tip of the day. #210
I had to pick up a can of sauerkraut for my wife yesterday. She is using it to make a chocolate cake!
Just cannot imagine this turning out well.
I kid you not.
RSKY
While there are certainly elements "Make Mikey try it", I think that, like Mikey, you will be surprised at how good it is. I suspect someone is a great cook, or she wouldn't be trying it. Sour cream is a great addition, too.
All the best,
Peter
TRAILBLAZER 325E FL GAS WELDER/GENERATOR (A54757)
TRAILBLAZER 325E...
JOHN DEERE 6155M (A53084)
JOHN DEERE 6155M...
UNUSED RAYTREE RMSG29 29" HYD STUMP GRINDER (A57193)
UNUSED RAYTREE...
2018 Ford Fusion Hybird Sedan (A53424)
2018 Ford Fusion...
2018 Dodge Charger Sedan (A55853)
2018 Dodge Charger...
70pc. 12ft. x 3ft. White Metal Roof/ Wall Panels (A53424)
70pc. 12ft. x 3ft...
