S854
- Joined
- Dec 5, 2017
- Messages
- 854
- Location
- Helena, MT
- Tractor
- ‘67 MF 135 Deluxe / ‘22 Kioti CK2610 HST/Bad Boy ZT Elite 54”
Just doing the first overall check of the new tractor equipped with R14T... I got to the "check tire pressure" portion of the show, checked the owners manual (which doesn't list R14) the closest I found was the "Industrial" tire--which matched the sizes I have on my tractor (15-19.5 & 27 X 8.5-15)... the owners manual requires 60 psi front, 41 rear... out of habit, I checked the sidewall for the manufacturers rating--which turned out to be contradictory...
One mark shows a load rating of 1860# @ 44 psi (these pics are from the front tire)
Another marking shows a Max pressure of 35 psi...
Neither of these pressures are what the manual suggests... "Keep the front tire pressure to maximum when using the front end loader..." is what the manual states... I.e. 60 psi...
I have sent an email to Goodyear requesting a clarification... I'll let you know what, if anything, I hear from them...
Right now I set the pressure on all four tires at 35 psi and plan on keeping my loader work to a minimum until I hear different...
EDIT: I found a related post regarding R14's and tire pressure... seems most prefer to keep their tire pressure well under the 35 psi MAX on the sidewall... most are in the 12 - 16 psi range...
Does anyone have a chart of recommended tire pressures for the R14? 16 psi seems to be a bit low for FEL work...
