Burn piles
/ Burn piles #1
ning
Elite Member
Northern California
Branson 3520h
/ Burn piles #2
nice to be able to do the burns since the fire ban was lifted here about 3 weeks ago. cleans up a lot of stuff
your pile size would win me a fine (unless with permit)
we have 6 inches of snow on the ground now
/ Burn piles #3
Did you melt the wires?
Cute cat! :)
/ Burn piles #4
That's either the biggest cat I've ever seen, or a very tiny burn pile.
Just kidding of course. I'm very surprised you are able to burn anything at all in California, permit or no.
We can burn here anytime as long as there's no "red flag" warnings (for drought/wind).
/ Burn piles #5
I'm the local pyromaniac....
Had the farm timbered, 20 years ago. The dudes left two HUGE slash piles (you can see backhoe in background of the double picture for sense of scale)
I've told this story before but what the heck. It had rained all week. This day was Friday and the rain stopped. So everything was soaked.....and this was a GOOD thing.
Called to get my burn permit, got home after work around 5:00 and headed out to light it off. Actually, to light THEM off as there were two of these monsters.
Got things lit. Hours later, it's cold outside BUT, I have "stereo heat" with both piles going. I found a spot where I could sit/watch and stay comfortably warm.
It was maybe 3:00 A.M. and I see a light dancing through the woods. Alas.... someone cometh. Light reaches me and it's a Sheriff. He seemed to have an attitude in his voice.
"Whatcha doing here?" (the word "BOY" was heard in the sound of his voice but he didn't say it)
"ummm... burning?"
"we got a report from across the lake that there was a forest fire over here....we've been looking for this for the last couple hours"
"mmmm..... ok???" (what am I supposed to say to that?)
"How are you going to put this out?"
This one perplexed me.
"Well.... I have my burn permit, I've got my phone with me (in case something gets out of control) AND, I've got my backhoe with me so I can keep tending the fire and be my own first responder if something looks like it's getting out of control" (in other words, I don't really have ANY intention of putting the fire out)
To which he then said with a bit of frustration in his voice...
"You DO know, don't you, that you are REQUIRED to be with your fires while they're burning???"
To which I looked at my watch and said "Well.... it's 3:00, isn't it???"
He muttered 'have a nice night" and left.
The bulk of the fire was out so I hung around for another 30-60 minutes.... then went home to bed.
It was however, nice knowing that the Kravitz family (sarcastic comment going back to Bewitched for the crowd that remembers Edna) was keeping an eye out on us!
/ Burn piles #7
Just common sense.
Good Point.
Just two weeks ago... I had a "large" (but nothing on the scale as above) burn pile. I usually burn in a dry-pond. It's a large depression in the ground, I have access to ALL sides with backhoe.
This was going to be my blow the leaves and cut the grass for last time day.... so I started this fire. Usually, I'm loitering around the fire to keep constant eye on it. I had leaves to blow and lawn to cut....AND the pond is essentially next to house so I can keep it in vision.
Except I really can't. Recall the comment about being in a depression? The fire itself is usually hidden from view because of being at a lower elevation.
Usually this is not an issue BUT, grass was dry. I was doodling in my yard and looked to monitor fire and I stopped..... quizzically looking at it. The column of smoke would normally be say, 10 feet wide. It's not 10 feet wide but maybe 50 feet wide.
Hit me immediately.... ran to backhoe, fired it up looked at field. Nothing was 'ablaze' but I probably had 100 foot "smolder" circle where the fire was burning the long/dry grass. So no 'flames' per se' but it was crawling AND heading to some slopes which would accelerate the spread.
I started using the front bucket to snuff the smolders out. Probably had 75% contained (some smolders would re-ignite to an active smolder but again, none of this was an "active" fire, you could stomp on it with your foot other than the big area to cover)
My wifes cousin happened to be leaving in truck, waived him down (he was with brother in law) so they both came over and stomped while I went home, filled two garden sprayers with water.
Got back and the flames were out but we moistened some of the smoking spots to be sure. Meanwhile, let the fire itself, keep burning.
That has never happened to me at this burn pit before....and the ONE time I "keep an eye on it" while being next door..... this happens.
Decided keeping the water in the garden sprayers will be a good idea from now on.
/ Burn piles #8
I have a 28' concrete bin pad, as my burn pile foundation. Has always worked well. Far enough away from the corn fields, and out buildings. I HAVE had the concrete "pop" a couple times (blew out a 4" deep, 36" across section), which gave me a bit of a scare. My fires are usually large, and hot... No permits needed here either. Calm wind is the hardest thing to schedule.
A couple years ago, the SIL set his cut corn field ablaze, when his burn pile got out of control. Got to about 1/2 acre and he called for the fire dept. They showed up and were disapointed that it wasn't a big(ger) problem. 😁
My last burn smoldered on for three days.
/ Burn piles #9
It's storming today with more storms expected on Saturday. I'm really wanting to buy some fencing on sale for Good Friday, and I have to go to my brothers farm to feed his cattle, but somehow, I really want to start my burn pile while it's so wet outside.
/ Burn piles #10
We have to have 6" of snow on the ground to get a burn permit. Then call the county sheriffs dispatcher the day the pile is set on fire.
I got to hate burning large slash piles as they took so long to burn. One year I got tired after 10 or so hours so piled a good foot of snow on the smoldering pile I had bunched up. The next morning, piled a good two foot of snow on the warm ashes and came back the next day and it was still smoldering. Smh.
Bought a chipper after that ordeal. I only have small fires now that easily burn out in a day.
/ Burn piles #11
Most counties in California have an official announced burn season. You need to notify the local fire station in case someone calls it in, so they don't roll to your place. If permits are required they are easy to get, usually on line.
The counties around the SF and LA areas are under more strict air quality regs and that can make burning more difficult as you need to meet their rules.
Other western states have similar burn seasons and in some places (i.e. southern Oregon), some air quality rules.
/ Burn piles #13
That's making quick work (y) hoping I'll be able burn our 2 piles when only coals remaing cook hotdogs sausages.
/ Burn piles #16
I'd like to suggest a way of disposing of brush and downed timber that (A) Reduce or elimintes danger of wildfire (B) alllows doing it on your scedule with less regard for burn bans (C) dramatically improves your soil for years to come. (D) Eliminate need for irrigation of deep rooted plants with as little as 20" annual rain or cut necessary irrigation dramatically for plants requiring alot of moisture. Bury it with soil and let it rot. Using land similar pictured in post 5 here's what I do. Use pictured tractor to pile brush in those small ravines and shallow creases in land. Due to amount of wood on ground in this case it would help to reduce it somewhat. Partially burn brush then cover in soil after small twiggs and limbs have burnt and flame dies enough to drive close with tractor. The partly burned wood is known as biochar,price it anywhere gardening supplies are sold and its value becomes apparent. Variables can change results but you can expect the 3' above grade mound to settle by 50% withing 18-24 months and be 6"-12" above grade withing 5 years. Mounds can be seeded as built then desirable plants,trees and grass after a few months. On a smaller plot I might dig a trench,fill it with brush then cover it with dirt as additional trench is being dug for more brush. I urge you to bury some rotten logs or brush to see for yourself even it it's only 15-20 sq ft area for a flower bed.
/ Burn piles #17
No permits nor approvals needed here. Just common sense..... I wait until I have a foot of snow on the ground before setting off my burn pile. Wildfires are just all too common in this neck of the woods.
Not much is more fun than burning a brush pile in the snow. I have only had the chance twice. We don't get much snow here. But it was fantastic. Next best is a pouring rain.
/ Burn piles #18
I burn a large pile every year or two. My current pile is scheduled for this weekend. My area requires a permit, which is cheap and easy to get. The requirements are pretty standard, and I follow them all in case I have a similar scenario with the authorities like @Richard mentions. That was funny!
/ Burn piles #19
i don't remember posting any pics of a fire with the cat in the frame.
I think that image was from a non-acclaimed movie...(as contrasted with a wildly acclaimed movie) one of those low low lowwwwwwwwww budget films.... you know.... "Attack of the Giant Cat" or "Fluffly, the Giant Mouse Killer"
2007 Chevrolet Express 2500 Cargo Van (A61573)
2007 Chevrolet...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2018 F550 Bucket Truck (A63689)
2018 F550 Bucket...
KUBOTA 72" PIN ON BUCKET (A64280)
KUBOTA 72" PIN ON...
Unused 10-16.5NHS Skid Steer Wheels and Tires (A61572)
Unused 10-16.5NHS...
2017 Cadillac Federal 70IN Limo w 27466 Miles, Premium Federal Coachwork, Luxury Transport (A63689)
2017 Cadillac...
