Burn piles
/ Burn piles #41
I do my burn pile from time to time. I had a fair size tree - maybe 15 in diameter in the pile along with brush and branches. Everything went fine, I left the ashes to burn out overnight. The following weekend, despite a light rain shower during the week, I raked around in the ashes and found some hot spots. No problem, I just left it. I was amazed the following weekend when I checked and still found some smoldering spots after 2 weeks! It really wasn't that big of a fire.
This issue is why I am reluctant to burn much of anything.
After forest fires out here, it isn't uncommon to have tree stumps and roots burning for months afterwards unless extinguished.
CA Tree Still Burning, 10 Months Later - Videos from The Weather Channel
All the best, Peter
/ Burn piles #43
I just had my largest bonfire ever. Had a pile of old scrap wood, junk pallets, busted shipping crates, old wooden furniture... the pile kept growing all year but the weather and my schedule didn't cooperate. It was hot and dry all summer and making a massive fire didn't feel right.
Well finally we got a few inches of snow, which saturated the ground and plants and made it time to burn down! Plus the night before Thanksgiving was 45 degrees, with no wind at all. Let's do this.
Kids helped me light her off, no accelerants needed.
Pretty soon it was ragin. I reloaded pallets and scraps about 5 times with the tractor & forks before switching to the grapple and attacking the overflowing brush pile (took down 10 trees this summer so had all the tops to dispose off).
We were gone all the next day for Thanksgiving stuff. 48 hours later the pile still looked like this.
I made a little magnet sweeper out of a kid's rake and a leftover subwoofer magnet. It works great but is quite small, hard to sweep such a giant pile. I was still burning my hands through gloves trying to get the nails off it so had to give the pile another day.
Now 72 hours from lighting the pile, I still had flames if I raked up the chunky coals. Yikes.
Then it rained and put everything out for good, phewf. But I still found chunks of coals in the dry ashes under the top crust. A little help from some newspaper wads and we were into the very final burn down.
Apologies to whatever critters had made a nice Den under the pile this summer. Maybe rabbits, but the hole looks pretty large. Would have expected to see groundhogs running about, so maybe fox?
Finally after many rounds of magnet sweeping, the ground is clean again. I buried the ashes in a hole behind the bonfire spot.
This whole process took WAY longer than I expected to get done with. And the main lesson for me? Make a permanent bonfire spot. This was just a temporary spot, which meant I needed to clean up all the nails. UGH! Guess I'll take this bucket and some other metal up to the scrap yard to make a few bucks.
/ Burn piles
If you don't do anything to encourage regrowth, it may be a few years before things are reasonably normal there; a fire like that is seriously sterilizing.
Remove the ashes, scrape up the dirt, add new topsoil, reseed.
/ Burn piles #45
Yeah I tried to scrape the ash off down to clean soil (not perfect) and then sprinkled some sandy soil back over top. I worked it a bit more after that picture but you are absolutely right. Would love to reseed asap but it's frozen soil time now. Probably throw some seed in May.
I have a dream to bring in my excavation guy and his dozer and turn this area into a larger flat area, maybe as a play/ball field, maybe for my future cash crop (lavender farm?). Not sure yet. So I wanted all the nails up, but dont mind burning the grass off this part for now.
/ Burn piles #47
I got scolded by the men in the big red trucks for this one. Wind came up and pushed the smoke to a development. I had my piles all lined up so I could do one after the other. First pile lit off hot and burned right up so I decided to do more than one at a time. As my luck went that day, I could not get the following fires hot and they smoked as you can see. Since then I have one burn pile and get it hot, then feed it with my grapple. No red trucks since.
Then
Now
/ Burn piles #48
The men in big red trucks aren't as cranky as the one in red SUV.
/ Burn piles #49
The red SUV shouldn't even be there! They just complicate even the simplest job.
/ Burn piles #50
Burning bonfire piles hot and clear is the only respectable way to go, IMO. For your neighbors and for the environment overall. Feeding one ultra hot pile location with a tractor grapple is an excellent way to keep things contained and controlled, but also hot and efficient.
Not awesome when people leave them unattended to smolder and smoke for days. My neighbor used to like to try to burn wet, fresh cut brush too.... so smoky.
I was bad about this one time myself. I was burning brush that would have gone pretty hot and clear, but then my brother-in-law heard my plans and brought over a trailer load to burn up also. But his was fresh cut cedar branches full of pine needles. Each load of that stuff put on the fire erupted a THICK yellow cloud of nasty smoke, that promptly blew over to my neighbors house when they were trying to have a covid-friendly picnic with extended family. I swear its the only time the wind has blown in that specific direction, but I kinda filled the woods up with smoke that day. They came over and asked if I could put out the fire.... had to say, sorry, but no not really. I stopped adding extra bush, but the existing pile is going to burn until its done.
/ Burn piles #51
And after you've cleaned up 'ALL' the nails, screws and bolts - you'll still be finding more nails a year from now. BT-DT. Hopefully by then they'll be rusted to the crumbling stage and not in your tire.
There's no bullet proof way around this problem short of scraping up the bottom layer and burying it.
BTW - that was a VERY nice fire you built!
/ Burn piles #52
Yeah thanks. It rained a bit overnight, so I'm going to check the area again today and see if any nails resurfaced.
/ Burn piles #53
We dug a huge hole with the excavator and have been burning in it for the last year. 3 early 1900s collapsed sheds have been burned in it, old fence corner posts with barb wire, staples, spikes, etc. Once it gets within a foot or so of ground level we'll push the excavated dirt pile over it, smooth the area out and dig another.
/ Burn piles #54
"The only way to keep nails from surfacing is to not put them in there in the first place." As instructed by my father. Jon
/ Burn piles #55
Man, ain’t that the truth.
These pallets had to go. But dang.
Soil was nice and dry yesterday afternoon, so i could drag my magnet through the top couple inches with ease.
Got this many more:
/ Burn piles #56
So..... I've got about eight inches of snow. Went out to check my big 'ol burn pile. It's all - sections of tree trunks and limbs. OOPS - too late. The quail have taken it over for their residence. I'll be letting Mother Nature handle this situation.
It's a whole lot simpler that way anyhow.
/ Burn piles #57
Yesterday, I checked the burn pile area I burned last Thursday. It still had some heat in the ashes. Used a fork on it and I could tell there was still some heat and a few small unburned pieces in it. But the pile had a lot of scrap from the saw mill logs, ie bark, wane etc. It burned well into the night on the first night. Next day still had a good size pile of coals burning. This is in comparison to dad's burn pile which are mostly brush trimmings from cedar and fruit trees. Jon
/ Burn piles
I can't agree more, and that's why I violate my burning permit stipulations of a "4 foot diameter" pile every time.
There's no way to get a 4 foot pile burning super hot; a quarter of it's burned before that much heat is produced and then it's dying out near the end without much of a coal bed.
I make a pile of dry, get the 400k btu propane torch out and get the whole thing going fast. Once it's too hot to get within 10', it doesn't matter if I'm putting fresh cut stuff on it!
/ Burn piles #60
Got this many more:
I collected over two gallon buckets of nails, hinges, screws, etc from my last burn. My burn pile is a 28' bin slab, but I move the cooled ashes to low area(s) so I want NO metal in there. There are two grassy areas the prior owners used for burning and I still find all sorts of metal stuff there, which I don't want to mow over...
2135 (A65055)
2135 (A65055)
2017 Ford Expedition SUV (A64557)
2017 Ford...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
APPROX. 6000 GALLON ALUMINUM LAY FLAT TANK (A64278)
APPROX. 6000...
2013 Kenworth T370 Petersen TL3 Forestry Grapple Truck (A64556)
2013 Kenworth T370...
2016 Ford F-250 Crew Cab Pickup Truck (A64556)
2016 Ford F-250...
