KIOTI no start, electrical
/ KIOTI no start, electrical #1
stancel
Slidell, La
Yanmar YM2000
I am out of ideas with my CX2510. It will crank when cold, but once warmed up it isn't getting power to the solenoid and doesn't turn over.
I have checked the PTO, Neutral, and Clutch safety switches and all have 12v passing through. Tested starter relay and ignition switch and both are good. Also verified the start fuse and made sure I was getting 12v on both sides. I don't think it is a short or compromised wire insulation because it only happens after it warms up, then no problems after sitting a couple hours.
I can unplug the solenoid and jumper it no problem and it operates as it should.
Anybody have any ideas?
/ KIOTI no start, electrical #2
If you can unplug the solenoid and jumper it for the tractor to operate normally it may be the solenoid. More specifically it may have an intermittent connection internally - perhaps a bad solder joint. Take a resistance reading of its coil when cold. Remove it from the tractor and pop it into your oven (not microwave!) and heat to 150 or so. Take the readings again. If they increase dramatically you've found your problem.
I ruled out the solenoid because I get no voltage at the solenoid harness when I turn the ignition key to start. I should be getting about 12v.
/ KIOTI no start, electrical #4
Does your start circuit have a relay? Relays can be heat sensitive.
If not you need to chase the voltage. Start at the battery, then check for power at the ignition switch in then out, then the various interlock switches in turn both in and out until you come to the solenoid. It's just a big loop battery-ignition switch-interlock switches in series-solenoid-ground through solenoid body-battery ground. There's a heat sensitive break in that loop somewhere and you can methodically check through it by chasing the voltage
/ KIOTI no start, electrical #5
It's time to break out a schematic. You need to determine which components may be warmed as the engine comes up to temperature. You may also wish to put an ammeter in series with some wires to determine if a current is being drawn somewhere when there should be none drawn. What you perceive as a heat related issue may be due to stray currents passing in the circuit when the key is turned on. This one may take some time and a bit of head scratching.
Unfortunately I don't have a wiring diagram for this thing.
/ KIOTI no start, electrical #7
I’m thinking that it may be a relay. I’ve had issues and replaced a relay which solved the issue I was having. Try banging or striking the relay to see if there’s any change…see next post
/ KIOTI no start, electrical #8
/ KIOTI no start, electrical #9
Your tractor has a Safety Start Controller mounted on the side of the transmission below the seat pan. Contact your dealer and replace the Safety Start Controller. The controller reads all of the safety switches, determines glow timing, and sends the start signal to the start relay. If you have already checked the seat switch and the start relay, you probably need to replace the Safety Controller Unit.
Hope this helps
/ KIOTI no start, electrical #10
Hope this helps
Like this? Do they have different ones depending if it has a mower?
/ KIOTI no start, electrical #11
There are different Controllers for the Cab or Open Station models. The Mid Mount mower does not affect the Safety Controller.
/ KIOTI no start, electrical #12
Michiganiron continues value add posts only a dealer can contribute. One reason why I buy all my parts and accessories from them,
/ KIOTI no start, electrical #13
Got a mid pto switch?
Hope this helps
Thank you!! I found a wiring diagram for a CK and saw it had a start circuit that everything fed into, but I didn't know if mine had it and where to find it.
/ KIOTI no start, electrical #15
Hope this helps
This guy says there's been a recall on the Safety Start Controller. Any validity to this?
2019 TAKEUCHI TL10V2 SKID STEER (A62129)
2019 TAKEUCHI...
New/Unused Landhonor Air Impact Wrench (A61166)
New/Unused...
250 GALLON FUEL TANK W/HAND PUMP (A62131)
250 GALLON FUEL...
2019 CAT 259D (A60462)
UNUSED ATS ME18 MINI EXCAVATOR (A62130)
UNUSED ATS ME18...
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC-55 55ft Insulated Material Handling Bucket Truck (A60460)
2017 Freightliner...
