Safety first! Cotton picker fire.
   / Safety first! Cotton picker fire. #11
Machine was running and he was under the head cleaning it with out blocking it up. A hydraulic line or fitting gave out dropping the head and he barely rolled out before it pinned him! Hydraulic fluid sprayed on hot exhaust then ignited is the best hypothesis of how blaze started.
I
Was the machine running or just the engine on? I sure hope he was not trying to clean with it running although I have seen people do that as well.
I have to agree that it is very easy to begin to trust the hydraulics after thousands of times of them doing exactly what they are supposed to. But that is when they are going to give out - after the thousands of times. A simple cylinder block is well worth it.
   / Safety first! Cotton picker fire. #12
I'll ask him about the machine running. I mentioned not blocking the head to go under he his reply was, "I have to do this 10 or 15 times a day, don't have time for that"
Hard to second guess the man doing the work.
Looks like that cotton was stripped. Was that a cotton picker or cotton stripper? We always raised tall cotton so never ran a stripper before but would think they would stop up more often.
Glad he was not hurt.
I've always heard it called a cotton picker or cotton combine. It's dumped from this into the compactor which turns it into big "modules". Most of the other farmers around here have gone to John deere machines that spit out wrapped round bales as it goes.
Engine running not head running.
I was just asking questions. He should be second guessing himself after this. I know of a couple people hurt while working on these machines. One used plastic buckets to block it up which were crushed when he took the hoses loose.
   / Safety first! Cotton picker fire. #15
Normally it depends on the type of cotton grown. Some cotton is a tall plant and the fibers are longer. It is better to use a picker on this type as it will be cleaner and bring more money at the gin.
Stripper cotton is shorter and has shorter fibers. The bowls will be closer to the ground and some even laying on the ground. A picker will leave a lot of cotton on the stalks with this type. A stripper will get most of it, even stuff that is on the ground. However the cotton will have more trash in it and normally brings less money at the gin because it is not clean.
   / Safety first! Cotton picker fire. #16
I know what he means.
People like to virtue signal about doing something safely until that have to do it 10x/day.
   / Safety first! Cotton picker fire. #17
I'm pretty free and loose with safety, but I won't go under anything suspended by hydraulics. I've had hoses go and it's scary even from the drivers seat.
I used to work under and around my loader all the time, always believing that any hydraulic failure would bleed down slow enough for my young and nimble self to jump clear if something happened. Then one day while lifting a brush hog (Woods PTO "rotary mower") up to pressure wash the underside and look for a leak, I had a hydraulic hose failure on my loader.
Hydraulic fluid shot 30-40 feet into the air, covering everything in a 50 foot radius, but more importantly, the loader with mower crashed down like a brick dropped from a building. There was nearly ZERO resistance due the expected hydraulic bleed-down, it literally fell with gravity. Woke me up to the possibility of what could really go wrong, and I haven't put any part of myself under anything supported with hydraulics, in the several years since.
   / Safety first! Cotton picker fire. #18
Bet he just found time for that now...
   / Safety first! Cotton picker fire. #19
I was lifting a full load of dirt out of the dirt pile when a line burst, covering everything, including me, with quite hot hydraulic oil, and the bucket fell like a rock. The hose failure wasn't a pin hole, it was more like what you see a water balloon look like after it's popped. Never saw it coming, no warning, just running, running, POP!
   / Safety first! Cotton picker fire. #20
Interesting. I'm probably more likely to get caught out by something i don't do on a regular basis. If it's something i deal with routinely, I'm more likely to figure out a way to do it more safely, and hopefully just as quick.
I grew up in a farming community and saw the impact on the families. I don't want to put that on mine.
SOFTSTART W/ ACROSS LINE BY-PASS STARTER (A58374)
SOFTSTART W/...
2013 Chevrolet Silverado 1500 Ext. Cab Pickup Truck (A55973)
2013 Chevrolet...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 Isuzu NRR Fuel Transport Truck (A56858)
2019 Isuzu NRR...
2011 Ford E-350 Cargo Van (A56858)
2011 Ford E-350...
