PT-180 Tram pump issues
/ PT-180 Tram pump issues #1
James23
Member
Minnesota
Power Trac PT-180
So some of you are aware that I have recently sent the Pump on my PT-180 back in to get serviced.
I got it back and was finally able to get up to my property this weekend to put the reman pump back in.
A couple hours later and I'm having some issues.
  • Pump is back in, all hoses are connected correctly.
  • Pump won't bleed (cranking and cranking, only air)
  • Bleeder hose has no pressure (stick my thumb on it, nothing....)
  • Decide to start engine. All hydraulics but Tram pump work fine. So pump shaft is turning.
  • when you hit the treadle, nothing happens, no nudges, no change in engine rpm, its like its disconnected.
  • Lots of cursing, kicking,swearing and inspecting the pump, I *think* the problem is uncovered.
I have a strong guess at what my issue is. I will be calling Terry in the morning here to have a discussion.
I have attached pictures of my pump before it left my garage and after it was re manufactured.
Anyone see any problems!??? (I am pretty sure I see the issue, but for fun lets see what you all come up with.)
/ PT-180 Tram pump issues #2
All I can say is to triple or even quadruple check all the hoses. And if you happen to use those plastic caps to block the lines while the pump was out, makes sure all of those are removed.
Also, and not to sound like a smart ar$e, you may want to address that positive battery terminal. Looks a bit nasty and could cause some weird electrical issues in the future.
/ PT-180 Tram pump issues #3
Not familiar with that exact pump but first question is where is the charge pump and is is connected properly?
No charge pump no working HST tranny.
/ PT-180 Tram pump issues #4
Dumb question, but did you prime the pump, i.e. fill the suction hose between the filter and pump with oil?
All the best,
Peter
All the best,
Peter
I did not, but I did change the oil filter and primed that. Do you think even after running it for ~5 minutes that there would be some type of air bubble in there still?
Edit: Terry told me to remove the top hose and fill the pump, which I did. So the pump is full AND the filter is full. I spend perhaps 10 sessions of 10 second cranks with the bleeder hose on the pump. Nothing came out (not even a spit or a puff).
I am not sure what a charge pump is, but if you are asking if I am literally missing a hydraulic pump of some type, No is the answer to that. All of the pumps that came with the tractor are on there, nothing removed.
/ PT-180 Tram pump issues #7
Since you observed that pump shaft must be turning due to the other pumps producing pressure (great observation!), all I can think of is that there isn't enough of a seal in the variable volume pump to suck oil. That's why I would think about putting some oil in the line from the filter down to the pump.
All the best,
Peter
I spent half the weekend driving around town to find a new battery. Turns out a "group 45" is rare. But a Group 51 is close.
To answer your question, yes I fixed that :).
Since you observed that pump shaft is turning (great observation!), all I can think of is that there isn't enough of a seal in the variable volume pump to suck oil. That's why I would think about putting some oil in the line from the filter down to the pump.
All the best, Peter
Do you see the open gap at the top of the "after" pictures. Notice how at corner the gap closes, but on both sides of it, the gap is open?
I believe that gap is showing me the internals of the pump. AKA that gap is not supposed to be there and beyond being totally screwed up, is not allowing the pump to develop suction. Sort of like how an engine can't develop compression if there is a large hole in the combustion chamber.
/ PT-180 Tram pump issues #10
Yes, battery replacements can be a pain. I think PT actually put in a post swapped version in my tractor as the negative crossed the positive originally.
All the best,
Peter
/ PT-180 Tram pump issues #11
Can you edit the photo and put an arrow to where the area of concern is? I may just be looking in the wrong area, but in the four photos I am not picking up on a problem gap.
All the best,
Peter
All the best,
Peter
I just added a new photo. If you click then click again (to zoom) I think it becomes more obvious...
/ PT-180 Tram pump issues #13
I don't think there is any pressure transfer through the pump sections. That gap shouldn't make a difference. There's a shaft in there that turns the piggy backed pumps, but it should have a seal. I think the tram pump should still work even if the two PTO pumps sections were removed. I could be mistaken, though.
As for a charge pump...
That's internal to the tram pump and not visible.
The tram pump in neutral just spins and doesn't move any fluid, because the swash plate is in a neutral position. When you push the treadle pedal, it changes the angle of the swash plate. The more positive the angle the faster you go in one direction. The more negative the angle, the faster you go in the other direction. It forces fluid through the wheel motors. So that's kind of a closed loop. But some oil slips past seals and case drains, etc. and goes back to the tank. The charge pump makes up that lost oil, and maintains a base pressure on the tram pump, as I understand it.
Also, the hydraulic filter only filters any fluid that the charge pump sucks in to the tram pump (suction filter). It doesn't filter any fluid in the PTO pumps that are constantly pumping. They have a separate intake(s) from the tank than the tram pump.
I'd guess when you install a new tram pump, you'd have to fill the unit with oil manually, then perform the bleed procedure until no air comes through the bleed hose back into the tank. If you're still getting air bubbles after several total minutes of bleeding, there's a couple reasons that I can think of.
Very low level in the hydraulic tank.
Filter not sealed to the filter housing.
Pump wasn't filled with fluid before attempting the bleed and doesn't have enough fluid in it to start suction.
If you're getting not oil coming out of the bleed hose, don't run the engine until you can get the bleed hose to pump out only oil into the tank by just cranking the starter in 10-15 second bursts (to keep from overheating the starter) with the spark plugs removed so the engine doesn't fire.
/ PT-180 Tram pump issues #14
ahhh, I see. That's a part of the tram pump, not the space between the tram pump and the piggy backed PTO pumps, correct?
Yes, to me that is part of the tram pump. Now I feel like that should all be sealed up, but I'm not entirely certain.....
The smaller pumps connected further back (that each have a hose on the left and the right) are working fine.
/ PT-180 Tram pump issues #16
In your fifth picture, I now see your area of concern. It does seem like you can see into it which seems...not right. I notice that there is a seal on the engine side of that gap, which leads me to believe that the area you pointed out should also have a seal, and in your great photo, you can see some ways into that gap.
If it were me, I would email Terry that photo, and explain your concerns.
If you are up for some non-destructive testing, I would pour some oil into the suction filter hose, and see if any comes out your gap.
All the best,
Peter
/ PT-180 Tram pump issues #17
I'm trying to remember what i did when changing my tram pump, but seemed like i filled anything that would take oil, pumps, hoses etc. And refill the many gallons of oil i let leak out onto the floor.
I did have one occasion after replacing oil filter where it leaked air around the seal. It takes a lot more turning then one would expect, from changing oil filters on engines. I can't hand tighten the hydraulic filter enough, i have to use a wrench to get it tight enough.
It will be interesting to see what Terry has to say about your pics. Nice pics by the way.
/ PT-180 Tram pump issues #19
James
I believe Mossroad answered the question on charge pump location but if it does not prime the HST will not work. I could not tell on the pictures which hose is the charge pump inlet but again per Moss it should be the line from the filter to the tram pump. This must be full of oil for the pump to operate. From what you are describing the charge pump is not priming to bleed the system.
That gap could be part of charge pump but again without knowing make and model of pump not sure.
So Power Trac is closed for the week. I will update this post next week after I talk to Terry. I am going to inspect is further this weekend, if I find anything new I will update.
