Time To Refurbish My Trailer
/ Time To Refurbish My Trailer #1
BoylermanCT
Barkhamsted, CT
Montana R2844, New Holland TC29D, Hustler X-One
I bought a used 6x10 trailer 10 years ago and have gotten a ton of use from it. But the floor was rotting out, everything was getting rusty and lights were broken or flaky. So time to give it some TLC.
I removed the lights, wheels, tongue storage box, sanded the entire trailer with a grinder powered braided cable wire brush, washed it, rolled on two coats of primer and the rolled on two coats of navy blue marine paint. I figured everyone has black trailers so I’d have a navy one! Put a new deck on, added a 7 wire junction box and 7 wire plug, ran new wires in plastic conduit including a ground wire to each light and new LED lights. Turned out nice.
Eventually I want to upgrade the axle and wheels from 3500 lbs to 5200 lbs with brakes so I set it up for a 7 pin plug in preparation for that.
Before
During
After
/ Time To Refurbish My Trailer #3
Goes with the truck color pretty well.
I tried to get as close as possible on a budget. Chevy NorthSky Blue Metallic was around $500 a gallon so I went with Rustoleum Navy Blue Marine Paint instead!
/ Time To Refurbish My Trailer #5
You did a good job. At least another ten years in it for you.
/ Time To Refurbish My Trailer #7
Very nice work. The results look good and the trailer looks to be well made.
You could get a drop hitch to level it out and distribute the load properly.
/ Time To Refurbish My Trailer #9
The drive might have a slope to it, causing the non-level look. Jon
I tried a hitch with a 6" drop and the trailer sloped down in the front. Then I used a 4" drop and the trailer slopes up in the front as in the picture. I need a 5" drop hitch which I could not find in the weight capacity I was looking for. I figured a slight up attitude would level out if we put a full load in the trailer as the back of the truck would settle a bit.
/ Time To Refurbish My Trailer #12
I solved this with a 6" drop hitch with a 1" rise ball.
2019 Toyota Mirai Sedan (A61574)
2019 Toyota Mirai...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
203201 (A60429)
203201 (A60429)
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
Ford 3910 Tractor w/ Great Bend Loader (A64047)
Ford 3910 Tractor...
