Sharpening drill bits
/ Sharpening drill bits
Hey, thanks to all for the suggestions. The drill-doctor idea is timely. Every year the kids ask me what I want for Christmas and I always say 'nothing'. This year I asked for a post-hole digger as one of the fiber glass handles shattered. But now, I will ask for a drill-doctor. Any particular model preferred?
This is the one I am looking at now - marked down to $149, plus a 10% off coupon, and it all comes to $145 out the door.
I don't think I will have the patience or skill to master the grinder process.
I can always count on this forum for help. So nice to have it.
/ Sharpening drill bits #12
The 750X is the one I have and I am very happy with the results.
I believe the cheaper one only does smaller bits.
/ Sharpening drill bits #13
Here's my tech tip... You put the bit in the holder and turn the holder around and around in the grinding hole. The holder rocks in a cammed action and the bit contacts the stone in about 1/3 of the circle. The rest of the rotation is nothing - air. So don't rush. Find the contact spot, keep even mild pressure and move slowly across the stone. On the initial sharpening I will even lift and go back to repeat making 2 slow passes on each side a couple of times, then go to a single pass but always going slow and deliberate over the stone at maybe 3 seconds a pass. This slow pass greatly speeds up the process... like using an electric knife sharpener.
When I got my first one I tried to quickly grind the bits and it took forever.
/ Sharpening drill bits #14
Still do it that way for large drills, but use a drill doctor (DD) on the smaller stuff; they become increasingly harder to see/hold/rotate as things shrink in size.
This is what drove me to the DD. I can do a decent job on 1/4-3/8 and up at the grinder, but that size and down (pilot hole size) I seem to go through them.
/ Sharpening drill bits #15
A+ on the DD
I needed one forever because I'm cheap
Finally got one
Years later I really really needed a sharp bit for something and finally used the DD - easy and super effective!
/ Sharpening drill bits #16
I've been sharpening drills since I was about 14. I started tool room training and was told, "A machinist that can't sharpen a drill is like a secretary that can't sharpen a pencil." I'm right handed, but hold the drill left handed. I could see the cutting edge easier that way. Now, sixty plus years later, I use a Drill Doctor on anything less than 1/4". The eyes just don't work like they used to. It takes practice, but then so does everything else.
/ Sharpening drill bits #17
wasnt going to ...but i have to say i have the Drill Doctor 750 also....wonderful tool. you'll love it
/ Sharpening drill bits #18
You Sir are not kidding. What I use to be able to do by eye... now I do by feel.
/ Sharpening drill bits #19
Way back when, where I went to college they required mechanical engineering students to take a 3 credit class in a machine shop. We learned to do things like run lathes, arc weld, and we even spent a day on learning the logic behind sharpening a drill bit. It was so useful. I have sharpened my own bits by hand ever since with good success.
/ Sharpening drill bits #20
Sharpen by hand guy here past 40 years. Learned the skill in a production shop drilling hardened truck chassis and we went through a lot of bits. Could even do 1/8" by hand and eye back then, not so much now.
Another tip is don't get the bit too hot or the new edge won't last long.
2014 Chevrolet Impala Limited Sedan (A59231)
2014 Chevrolet...
Service Truck Body (A59230)
Service Truck Body...
Case-IH 165 Puma (A57148)
Case-IH 165 Puma...
Takeuchi TB016 (A53317)
Takeuchi TB016...
Teak Wood Dining Table (A59231)
Teak Wood Dining...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
