Fly by wire, no linkage on OP's tractor.Check for play in the linkage between petals and actual swash plate. On my LS the heim joints like to come loose.
I have also (in the past) experienced jerky response after several hours cutting grass on a hot day on my hilly property. When I got out of the cab I could feel the heat radiating from under the tractor. So this experience is possibly linked to hot fluid. After the tractor cools down some it runs fine. If I'm not running the PTO on hilly terrain it run's fine all day long. I changed the method I mow which seems to help. I now mow in low gear and the pattern is strictly straight up/down the hillside where I would mow horizontal before in medium gear.Fly by wire, no linkage on OP's tractor.
My NX can be jerky as hell usually on medium range pedal to the floor and it's when the fluid has warmed up. I can set cruise and it stops and travels smoothly. I've figured out a bunch on my tractor but not this one yet.
Back in June of this year I had issues with my 2014 NX4510HST. It has 900 hours on it now. Regardless of the gear that I was in it showed L in all 3 speeds. The N worked in neutral. I took apart every connector on my tractor and plugged them back in. I looked for branches stuck up under the tractor. There were none to be found. The Calibration light was on and my tractor did not move. It took many times of running the calibration sequence before it finally took and I had my tractor moving again. This happened again on Saturday to me. This time the H light was lit in all positions including the nuetral. After many times of reseting the calibration sequence I was up and running again for a short period of time. I must have run that program 40 times yesterday to get my work done. Now I have a flashing Cal. light. The tractor will run in this mode but is very jerky to start off. Anyone have any ideas on this before I bring it to the dealer. I also should mention that while the H light is on I also have a dim L light on and no N light in nuetral. To start my tractor I have to jump the solenoid.
My jerky motion also only seems to occur when the hydro fluid is hot. Normally the hydro fluid only gets that hot when I'm using the PTO for an extended period of time.Fly by wire, no linkage on OP's tractor.
If it is a two-wire, then one wire is the signal, and the other wire is the reference voltage. You want to tap into the signal which will be a lower voltage than the reference voltage. Reference voltage comes out of the ECU, and is modified by the sensor. The reference voltage may be battery volage, maybe 12v or something less.I'm going to look for it but the diagram shows a iron core inductor symbol instead of the usual resistor type temp sensor. I did a internet search for a Kioti oil temp sensor part but can't find anything.
It might not be the same issue, but have you had the dealer do the NX update that came available in May (I think) of this year? The dealership in my area had a “stop sale” order for the recent in-stock NX series from 2020 forward pending release of the update. It was due to operational issues much like you describe.Anyone have an issue like this?
While using my PTO stump grinder in low gear where I need to be able to move slowly the transmission is jerky.
Specific details are sketchy, but from chatting with my dealer, it involved several new grounding straps and a software tweak. Supposedly, this fix applied to the NX series a fair bit older than my 2020.
Not that I recall, but I’ll contact them for a reference and post it here. I’ve only put 30 hours on the tractor - mostly moving snow- but have had none of the heretofore mentioned transmission issues so far.Did your dealer happen to mention an update number or reference source? It'd be sweet if a software update and a few grounding straps fixed the issue(s).
