Small but annoying problem..
/ Small but annoying problem.. #21
Hard nylon washers.
Or... a wavy washer would eliminate the slack/noise. Those are available on Ama... either single size or kits.
/ Small but annoying problem.. #22
it's not a problem because I wear hearing protection for the noise, but I don't want to use them all the time when I shouldn't have to.
I know nothing about your machine so if it's otherwise super quiet... I didn't know and pardon my ignorant comment.
So you understand my point of view:
1. backhoe has a cab but all glass has broken over years so all engine noise comes to ears.
2. Tractor (International 1066) can make a ton of roar when at full throttle
My opinion is it's ALWAYS good time to wear hearing protection....ALWAYS.
So if hearing protection fixes your problem.... and it's advisable to wear hearing protection.... do you really have a problem?
Just make it a habit of putting them on and save your annoyance.
/ Small but annoying problem.. #23
I think this is something similar to the hinge he is refering. On the second or third day I owned my TC33D I cut strips from a old tractor intertube and stuck them between the hinge so that when they were compressed it really added tention in the joint. They have been there for about 20 years now and still work just fine to eliminated the clanking.
/ Small but annoying problem.. #24
rubber tubing from an inner tube might work, it would have some give so that it doesn't vibrate out
/ Small but annoying problem.. #25
The ROPS on my tractor has a fairly large knob at each hinge. The knob must be loosened in order to draw out the pin that holds the top hoop in either position. The knob turns a bolt that pushes against the square tubing that the hoop is made of so that everything is rattle free. This link: Husqvarna ROPS Kit MZ/MZ-T #575274801 | Safford Equipment Company
shows a similar ROPS. The bolt just loads up the joint so that it doesn't rattle. The bolt is placed far enough away from both the pivot and locking pins that it has significant leverage which then puts significant force on both without someone needing to be Hercules to tighten the hand knob. You would need to drill two holes and weld a nut to the structure but the solution would be permanent and work well. Drop by a tractor place and look at what they sell. From looking online it seems that the knob is a common feature. Mine is on a Yanmar YM2310.
Eric
It's true the Workmaster 40 is much louder all around than the very quiet TC26DA that preceded it, but It's still quiet enough at most RPMs to drive comfortably without hearing protection unless there is something noisy attached, like a box blade, etc. I generally have the ear flaps on board, but just don't like to use them when they're not needed. When mowing with the RFM, they're definitely needed. In the summer, they're hot, and in the winter, they can be a PITA with winter hats on, though with the rear blade, once there is a packed base, the blade makes very little noise. So, I enjoy riding around without them when I can, and it also allows me to hear any unwanted sounds coming from anything mechanical, that I might miss with hearing protection.
From my experience with these two tractors, it's obvious to me that there is a huge difference in the amount of racket CUTs generate. Took me a while to even track it down to the ROPS. At first I thought the rattle was coming from the pin-type things that replaced the turnbuckles on the lower arms. Years ago, when riding around on my uncle's farm tractors with hay balers and wagons attached, the noise was not all that much.
/ Small but annoying problem.. #27
My ROPs has two bolts on each side. One is the hinge bolt - the other tightens the ROPs down. Maybe a little bit of welding to make brackets to tighten the ROPs down.
/ Small but annoying problem.. #28
I can't believe I'm actually asking this, but all previous attempts have failed.
I like my NH Workmaster 40, but one thing that is driving me batty is the racket generated by the ROPS at the junction where they are hinged. I've tried various shims and things which work for awhile but vibrate free, disappear and don't last. Finally today, I cut strips of neoprene and put them in between, clamped it down and it worked beautifully for about 15 minutes at which time the ROPS cut the neoprene strips in pieces.
Anyone out there know a material that would work for this? When mowing, it's not a problem because I wear hearing protection for the noise, but I don't want to use them all the time when I shouldn't have to. I've tried wood and plastic shims, and the neoprene. I was thinking maybe peelable caulk because I don't often put the ROPS down, but that might cut just as easily.. Don't want to use anything that would fuse the ROPS up permanently. My TC26DA never made any noise from the ROPS.
Yeh, this is a common complaint about folding rops. I have buna-n backup rings from work, so just fit that in there to take up the space (when I had the tops of the rops still on). Otherwise, Ace hardware or whatever has nylon washers in all different sizes. Just buy a few of those, fill up that gap with a one or a few of them, however many it takes, you'll be good to go.
OK.. I thought about the inner tube solution but since they cut through the neoprene, they'd likely cut through that as well. Current solution that is working on 3 days is cutting fingers off of old leather work gloves and squishing down on them. So far, great relief! Time will tell.
The TC 26 DA had a completely different folding ROPS system and never made any noise at all.
I do a lot of moving firewood around running at low rpms and that is where it gets on my nerves. Mowing or dragging a box blade, of course, require hearing protection anyway.
Thanks for all the suggestions!
/ Small but annoying problem.. #30
If the leather shreds, maybe try easing/rounding over the sharp edges with a file where it's cutting & go back to something squishy. or coat mating surfaces with liquid electric tape & see how that holds up after it sets up.
/ Small but annoying problem.. #31
You glove solution may work, but anything that is durable is what you need to take up the gap, maybe some thick plastic. If the gloves don't last try something else and I'm sure you will eventually find something.
Yep, the left side had four plastic bumpers, the kind used for cabinets, and they held up for quite a while. They're still there with the glove finger between. I could use some old shoe leather if the glove stuff wears out too fast, but even if they last a month or so, I always have worn out work gloves around.
/ Small but annoying problem.. #33
I used a small piece of 1/2” per pipe and shut the rops on it.
/ Small but annoying problem.. #34
Like 5030 mentioned, a plastic washer at the hinge point and tighten it down well. I did that on my Kubota (2 on each tube) and it silenced the ROPS. Haven't had any noise all year. I usually leave it folded down, but it hasn't impeded folding back up when working on slopes.
Replace pins with bolts and just loosen when u want to fold it down (my NH has pins at the hinge point). Just a thought.
