First tractor owner L3000DT, 3 point hitch surging
   / First tractor owner L3000DT, 3 point hitch surging #1
DBLA
Florida
Kubota L3000
First tractor owner, 2001 Kubota L3000DT
My three point hitch is surging in any up position, won't hold implement up unless completely close the "3 point hitch lowering speed knob". The surging seems to be the hitch trying to keep the implement up, but can't because of a loss of pressure. Anyone have any info on how to fix.
   / First tractor owner L3000DT, 3 point hitch surging #2
If you have hyd outlets on the tractor, make sure the control valve(s) are in the neutral position and not stuck open. Also check the FEL control valves if the tractor is equipped with one. A stuck valve can cause a loss of pressure through the hyd relief valve.
   / First tractor owner L3000DT, 3 point hitch surging #3
Also check the hyd oil level, it could be low enough it lifts the arms and then pumps air so they drop. Unless you know it has been done consider changing the hyd oil and filters for could be issue there. If it works fine when cold and first cranked it could be getting air in the system (probably the suction side) or has water in the oil as it heats up it gets worse. kt
No problems with FEL, all fluids at prescribed levels. The surging takes place whether at first crank or after hours of use. Is there any kind of alignment or adjustment that would cause this?
   / First tractor owner L3000DT, 3 point hitch surging #5
Did you ever resolve the issue? If so what did you do?
   / First tractor owner L3000DT, 3 point hitch surging #6
Most likely a leaking seal in the three point lift cylinder. Cylinder leaks down and three point position control tries to hold position so it constantly cycles.
2015 Nissan Pathfinder 4WD SUV (A56859)
2015 Nissan...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
2001 GMC C7500 SINGLE AXLE VOCATIONAL TRUCK (A57880)
2001 GMC C7500...
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
