Good morning!!!!
   / Good morning!!!! #158,301
I'm in Raleigh.... Keep them supplied with the healthy food and more importantly the sweets...
Hope you have a good trip back to the Washington area..
Mark
   / Good morning!!!! #158,302
RNG, listen to Supertramp much?
what goes up doesn't necessarily come down.
Supertramp occasionally finds their way into the mix. Just two years ago we had $2/gallon fuel, so I believe it can happen again with the right policies in place.
Got the safety chain hooks installed and the snow implements pammed.
Get one of these and you can spray whatever oil you want. I mostly spray parts cleaner solvent with a smaller version, and I've forgotten what I sprayed with this large version, but it worked fine...
   / Good morning!!!! #158,304
sc, while you were into 'tramp in the '80s, I was into Pink Floyd.
The very best way to go to any concert is in a hired limo. Then you could get as wasted as you wanted and didn't need to worry about a DUI on the way home.
   / Good morning!!!! #158,306
What size pex for air? Use a regular pex street elbow? .
I use 1/2” PEX-a (or expansion PEX) because I’ve got the tool to expand it.
For the fittings, I use a drop ear ell or tee that is PEX x FMPT. For running ells or tees, I just use the plastic ones.
   / Good morning!!!! #158,307
62F overcast.
Okay day at pt, job than it's been kinda ho day,nothing plan for the evening.
Enjoy your evening all.
   / Good morning!!!! #158,308
Thanks popgadget. Running an air line might push me over the edge to buy the expansion tool.
But I have so many unfinished projects now….
   / Good morning!!!! #158,309
I never let an excuse to buy a new tool get away.
Two considerations about PEX-a.
1. It is more expensive, but better specs and far easier to work with expansion fittings than crimp rings.
2. A lot of hardware stores and home centers don’t carry it. Lowes does, HD doesn’t. Pretty much all supply houses and plumbing supplies do.
   / Good morning!!!! #158,310
Good (Wednesday) morning. Overnight Low of 5C and it's currently 19.1C (which is 4 degrees above the predicted High). It's a glorious sunny day and nearly calm. There was 4.5mm in the gauge at 0900, but that was from yesterday early arvo whilst I was in Launceston... according to the Aerodrome, it all came down within an hour and a half.
It's 'into-town-day', where I'll check my mail and post a couple of parcels, top up my petrol from yesterday's travels and do my weekly grocery shopping.
The weatherguessers say that things will (finally) be dry around here for quite a few days. A good thing as it's still very 'squishy' around the property.
78" GRAPPLE RAKE (A52708)
78" GRAPPLE RAKE...
Zero Turn Mower (A55853)
Zero Turn Mower...
1408 (A57192)
1408 (A57192)
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58216)
2002 AMERITRAIL...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
