Zero Turn front tires
/ Zero Turn front tires #21
Another vote for tireject. My front ztr tires leaked constantly, haven't leaked for months since I used the stuff.
/ Zero Turn front tires #22
My front tires keep losing air (slowly) and I'm tired of putting air in the tires. I have to use a foot pump because the valves are difficult to access.
Anyone use solid tires on the front of their zero turn?
Front Solid Tire Puncture Proof
I have the Michelin Tweel wheels on the rear of my 2200 Ferris, and no-flat tires in the front. I don't know if they are hollow or solid. Don't care. I think the ride on both is a tad harder than the air tires, but with a "good" seat it doesn't matter. I'm on my mower 6 days a week, and used to get flats once a week. Now, now none.
I love 'em.
/ Zero Turn front tires #25
I fought slow leaks in front for a couple of years. Then I put tubes and still had leakage. Finally went to front solids. Now no more leaks but harder ride. I wouldn’t switch back.
/ Zero Turn front tires #26
when one of my mower tires goes flat...I just get a tube installed and never have a problem again...
/ Zero Turn front tires #27
My 2006 Exmark came with solid tires, never any problems, other than a bit of a rough ride.
I installed a suspension system under the seat, did same on the crappy factory seat on the tractor. That helped quite a bit.
/ Zero Turn front tires #28
I had a tire leaking on our Bushhog ZTR and they had an option for a "Run Flat tire" I thought it was a solid tire but it is actually not solid but has no air valve stem either. It is hollow with very thick sidewalls but still flexs some. I haven't used it with them yet but my wife said she doesn't notice a difference from the old Pneumatic tires. I ordered them from the Bushhog site.
/ Zero Turn front tires #29
You’d be surprised at the amount of cushion low psi tires provide. A solid tire would beat the hell out of you on a ZTR
They aren't actually solid tires.
The oem flat free tires (semipneumatic) are as soft and squishy as a pneumatic tire.
If you are actually shopping for a "solid" tire you are shopping for the wrong thing
/ Zero Turn front tires #30
I foam filled the front tires on my zero turn. It did make the ride slightly worse but the front tires don’t provide much cushion. I wouldn’t foam fill the back tires because they definitely do provide a lot of cushion. My front tires are pretty much worn out. I might look for a set of soft flat free tires to go back on the front. I’ve not had as much trouble from the back tires going flat. And most run flats are a turf tread and I’m pretty set on using AT-101s.
2012 Freightliner M2 106 S/A 14ft. Cab and Chassis Truck (A64194)
2012 Freightliner...
2016 INTERNATIONAL PROSTAR 6X4 T/A DAY CAB TRUCK TRACTOR (A67147)
2016 INTERNATIONAL...
2014 Chevrolet Impala Sedan (A64557)
2014 Chevrolet...
2022 Chevrolet Tahoe SUV (A64557)
2022 Chevrolet...
2018 Bomag BC572 Articulated Refuse Compactor (A64553)
2018 Bomag BC572...
2005 Anderson 24ft T/A Dovetail Tag Trailer (A64556)
2005 Anderson 24ft...
