3 Point Log Splitter
/ 3 Point Log Splitter #1
walker450
OK
M5040, BX25D, F2880, ZD1211, GR2120, KX-040-4
Made a quick video, hopefully it is helpful to anyone considering a 3 point splitter. I picked this one up for $250. I added the "table" area at the back to keep logs from falling down. I added a control rod coming from the tractor hydraulic block to the area where you stand. This is a simple method but only works for this one model tractor.
/ 3 Point Log Splitter #2
Like the table you added to it.
Buddy of mine has a 7 ton on his Kubota. Pretty nice to be able to lower it down for the big (100lb ish) rounds, then move it back up to hip level to split the rest.
/ 3 Point Log Splitter #3
My 3 point splitter is one of my best buys! My wife agree's and loves to run it!
It's fast and easily pushes everything through the 4-way wedge.
SR
/ 3 Point Log Splitter #4
I hope that's not full tractor rpm..that thing is slow as hell.
/ 3 Point Log Splitter #6
SR
Yours looks like it has a PTO driven pump, if so I suspect it is considerably faster.
/ 3 Point Log Splitter #8
Nice set up... Fortunately you have it on a tractor with enough extra gallons per minute to give a decent cycle time...
I have been involved to make parts for some homemade 3pt splitters that worked well other than the compact tractors they were mounted on didn't have enough flow to make them work well...
/ 3 Point Log Splitter #9
I have one without a PTO pump too, there's a huge difference in speed, but it does work well even though it's on the slow side.
SR
/ 3 Point Log Splitter #10
I have a 3 point mounted splitter as well run off the tractor hydraulics. It is not fast, but it allows me to split, stack, and get the next piece to split. Reality is, the splitter is usually waiting for me when I do that sequence.
Yes it is slow as hell, that is at 1400RPM and PTO speed is approx 2200RPM I believe. Increasing throttle beyond 1400 makes it cycle only slightly faster and isn't worth the extra wear and fuel burn in my opinion.
It's what I have and it works fine for me, I'm not in business it's just personal use.
/ 3 Point Log Splitter #13
When we first moved here it was firewood. My ancient Ponderosa pines are 24" to 36" on the butt. I tried a splitter maul - ABSOLUTELY no go. I looked at a 3-point splitter and a stand alone splitter. I chose the stand alone splitter. I could get the stand alone low enough to the ground that I did not have to lift the rounds. Dig a shallow trench with the bucket - roll the splitter into this trench. The splitter was then just about the same height as the ground.
For the first ten years or so - five full cords of firewood every year. Then we went to pellets for the next fifteen years or so. Now it's electric heat.
2022 EZ-GO ELITE...
2026 DEVELON DX27Z-7 EXCAVATOR (A65053)
2026 DEVELON...
New/Unused ATS 40 Gallon 2 Stage Air Compressor (A65583)
New/Unused ATS 40...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
2009 BMW Sedan (A61569)
2009 BMW Sedan...
2023 Case TV380 (A62177)
2023 Case TV380...
