Kubota Link Arms
/ Kubota Link Arms #1
mrgrigsby
L2501 Kubota HST 4 wheel Drive
I am trying to determine the factory length of the (r) and (l) lift arms, sometimes called a leveling box. Once on the right is adjustable and the other is not. Specifically I need the overall length of the part number T6146-39100. My local tractor parts store (Tractor Supply) list two different ones but no model of tractor that they fit nor which factory part they replace. so which one would I need to replace the left (non adjustable) arm?
/ Kubota Link Arms #2
Would these be for your L2501 or some other tractor? If they are for the L2501 I'm sure someone (even me) could measure the existing arms.
/ Kubota Link Arms #3
Sorry to muddy the waters, but Kubota lists (2) part numbers for the lift arms as "old" and "new". Neither part number I ended up with matched the op's part number.
Assuming for an L2501.
/ Kubota Link Arms
Do you mesure from the center of one hole to the other or is it the overall length?
/ Kubota Link Arms
Yes, I have found they have changed designs with some of their parts, one if the turn bunckle being replaces with adjust sway bars, a much better designs in the newer tractors as well as adjustable arms that extend out.
/ Kubota Link Arms #6
You sure the stabilizer arm opposite the bevel box isn't adjustable, mine are on my M9's, though I've never adjusted them as the bevel box is sufficient for levelling the lift arms.
/ Kubota Link Arms #7
Kubota B26
Weaver’s tractor had several leveling box options. Giving good detail on specs on length and styles. Makes adjustment easy.
Note the blue U at top of level box. To fit my application required a left over piece from modifying the pin style sway control bars. They had those too.
/ Kubota Link Arms #8
Telescoping sway braces and extending drag links are the bomb. Add hydraulic lift and tilt and you got a dream machine ;)
/ Kubota Link Arms #10
Like your coordinating color choices...lol Have a spare can of Kubota grey in the shelf I can send you....
Have you priced tractor paint lately? That paint is like gold. You better hang onto it ;)
2017 Chevrolet Tahoe SUV (A64557)
2017 Chevrolet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A65643)
2020 TROXELL...
1997 Dodge Ram 3500 Dually Truck, VIN # 3B7MC33D5VM559525 (A65563)
1997 Dodge Ram...
Quick Attach Bale Spear (A66408)
Quick Attach Bale...
2002 Freightliner School Bus (A64194)
2002 Freightliner...
Bradco 8611X Backhoe Attachment (A65579)
Bradco 8611X...
