Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace?
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace?
No contamination issue, go right over it. I did three more rods this afternoon.
I have lots of scrap rods, too bad you are so far away.
What would you want to ship me a few?
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #22
Only the cost of shipping. You want small slugs to practice on? I could do a USPS flat rate box. Larger rods could get pricey to send….lol
Sure. Price is always a concern. Give me an idea, medium or small flat rate? And how to pay for them.
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #24
OK, I’ll check out the USPS rates and PM you
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #25
Here’s one of many I’ve done this past couple of weeks.
This bucket cylinder rod today from a 88k lb Cat machine. 130mm rod x approx 7’ long. It’ll be going back together in the am.
Edit: from a 145k lb machine (Cat 365)
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #26
And another weld up on a valve spool. This pic shows the corrosion before.
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #27
…….and here’s the finished spool just before final polish, ready to go back together.
   / Resealing stabilizer cylinder, nick in rod. Fix, ignore, replace? #28
I have heard of clear nail polish or super glue being used but I have not ever tried. This was a suggestion from a random auto mechanic that seemed a bit out there. Might be able to google those and see if any results pop up. Stabilizer cylinder would be about the best spot I could think of to try something like that as it’s not being extended and retracted as much.
UNUSED 30PCS Brown Metal Roof Panels (A53117)
UNUSED 30PCS Brown...
2016 R and R Products 331 LP Reel Mower (A51694)
2016 R and R...
2017 Ford F-150 Pickup Truck (A53422)
2017 Ford F-150...
Honda EU3000is Gasoline Companion Inverter Generators (A55851)
Honda EU3000is...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
1996 FORD F-SERIES FLATBED TRUCK (A52706)
1996 FORD F-SERIES...
