Would it be possible to convert a lawn mower into a lawn "tractor"
   / Would it be possible to convert a lawn mower into a lawn "tractor" #21
Forget my earlier response. I just looked that model up on Tractordata. OMG, I think this has to be a spoof or joke. No one but a complete fool would try to turn that LT into a ground engaging tractor w/ 3pt. capability.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #22
I would watch the ads for an old diesel subcompact tractor. Sometimes they can be bought cheaply and restored to full functionality. This means at a minimum: low gears, strong drive train, 3 point hitch pulling and lifting ability. The good ones also have potential for a loader, 4WD, low range, and additional hydraulic valves for a dump trailer, and a life expectancy measured in generations. Gray market tractors come to North American shores quite cheaply when they are dumped by their owners in Japan. Dealerships don't support these machines. On the other hand Bolens, Yanmar, Kubota and many others marketed garden tractors since the early seventies. In 2010 I bought a 1980 Bolens G174 tractor with a 48" pto lawn mower. The tractor was $3000 CDN and the mower another $300. Looking back after 12 years of service, I can safely say that the tractor was a good purchase. In my case I needed a machine to get into tight spaces. The Bolens will back my 44" by 84" hydraulic trailer into my shop, through the power tools, to the woodpile by the box stove, where I unload and pile each load. It also gets through the many rows of trees on the property. It's not heavy enough for a 5' box blade or a 7' blade, though it will carry a 500 lb. 3pt hitch winch into a tight space and power the windlass to extract logs from tricky spaces. Just don't ask it to skid them.
An even better buy a few years later was a 2005 Kubota B7500 HST with a 5' belly mower for $9600 CDN with only 210 hours on it. It has proven loud, effective, and trouble-free over another 1300 hours of operation. It does a lot of lawn mowing, and runs my 4" pto chipper, 48" bush hog, and block splitter and dump trailer through its auxiliary hydraulic feed.
My avatar photo shows this summer's acquisition. This Case is another Mitsubishi, a direct relative of the Bolens, with 1450 hours on it, though it is about a 1990. Time will tell if was a good buy.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #23
Hi all. So this is Abit outlandish however I feel like there may be some feasibility. My consideration was to have a small lawn tractor such as a cub cadet lt 1042, gear down the hydrostat so it puts slightly less strain on the system, and re-route the belts to a custom built pto assembly running off the back of the mower, aswell as a winch assisted 3 point. Atleast in theory it would preform similarly to a small 13hp Kubota, and cost far far less. In terms of engineering I have the plan of what to do, however the issue is I'm not sure if itd actually work
Haha I have the money dw lol, if need be I can buy a little subcompact outright, but I still want to avoid spending 30K on something yk? Rather invest it
Maybe look at an old Can Cadet Garden Tractor. They have real robust frames and drivetrains. Something like their old 782. Many came with cat 0 hitches.
Having said that..
I would never deny anyone a garage project.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #24
Booo. I turned a '72 Chevy Vega into a Drag car. That is a no frame 4 cylinder putter.
Just so you know what you are in for, garage projects are frustration and theoraputic.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #25
All the comments are relevant to a degree. That said, I had a consumer grade 15.5hp MTD with variable speed transmission (not Hydro). For me, it was tough as nails. In its later years, I used it as a rough cut mower - cutting brush up to 3/4+" diameter. Should I have? No. What I learned is it was more capable than one thought if you pushed its limits. I helped a friend make trails on his land, and he couldn't believe it.
Its only problem was that I needed more clearance for uneven ground, stumps, etc. That is why I always dreamed of building a lifted mower. I always thought Swisher or DR should make a lawn and garden tractor with more clearance and a rough cut mower deck that could mow from 3"-6". Perfect for lawn or trails.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #26
Look up "lawn tractor mud mower", and you'll get an eye full of mod ideas. As far as adding something that would add actual stress to the machine like a 3pt etc, the units are fairly light, and I doubt much work would get done with it. The minute one thing is beefed up, something else would fail to compensate. I used to have a 11hp murray that I used as a tow unit, for pulling a 4x8 trailer and brush mower around the woods and camper around the yard. It did serve the purpose, but there are better ways. It was fun though ripping around with it.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #27
   / Would it be possible to convert a lawn mower into a lawn "tractor" #28
I don’t believe you will find a cub cadet 1042 has a frame. Nor is the drive train designed to engage in dirt work.
I believe your time and effort could be put to much better use. Find an older true garden tractor to do the chores that you are wanting to do. An older cub cadet, John Deere, wheel horse, or economy tractor will allow you to truly garden. It’ll take some time and effort to shop around to find a quality used unit.
If you’re able to find an International Farmall cub you would truly have something you could garden with.
These new lawn tractors are really not much more than lawn mowers and have really limited abilities to Tractor.
Totally agree with the Farmall Cub advice! A great tractor with lots of simple to use implements available, if you have the patience to look for them.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #29
I too agree with almost everyone here, to some extent. šŸ˜‚
One difference perhaps being, i HAVE made a riding mower do what it was not supposed to do.
It was sort of a big project even though it didn't cost much. I put a small push mower engine on pushed as far back as possible to make room on the front of the frame, reinforced the frame (after bending it) with welded angle iron (but never bothered to run the self-tappers back out lol). Moved the front axle all the way to the front, lengthened the steering rod, added thrust bearings under front spindles, matched up different wheel halves on skinny 4.10-4 tires to tuck the front tires in as close as possible to reduce scrub radius (to minimize steering effort), moved front axle up to hit frame to defeat tilt/pivot (to mitigate tendency to tip over if back wheels come up) built a throttle bracket to idle the engine down, used an ac accumulator as a muffler, used a fan clutch as a flywheel on the engine, pressed a drive belt pulley onto the pushmower blade hub, added 4 bolt wheel adapters to run car tires filled with liquid, another liquid filled wheel on the back, heavy brake drum behind the 'spare' tire for weight, brake rotors behind the drive wheels for weight, stock ~3.5gal fuel tank filled for weight, notched the dash to stow the crane under the hood for weather resistance, etc etc.
In the end it DID work well and could do things my FEL tractors I bought later could not do, like deliver engines through 30-something inch wide openings. Moving engines across dirt and gravel is what i built it to do, it definitely does that. I have had 500lbs on the crane and the back stays down without me sitting on it.
So sure, if you want to then go for it. But understand you might get more out of the learning process than you do out of the machine you'll build. But as far as building things, you gotta start somewhere, and it helps if its cheap and the stakes are low! That's what made me pull the trigger on this thing. I had everything except the $130 crane, and the 4 bolt hub adapters. I put maybe $250 into the conversion, and the rest of the major components i had sitting around.
I also own a garden tractor and a SCUT w/fel and if you want to skip the fab and just get work done you should definitely go that route!
The Case i got with no engine for $250, put a $99 HF predator 212 in it, and made the missing 3pt parts it didn't come with out of scrap car parts. It's vastly more capable (3pt can also pick up about 500lbs, just not as far out because there's no weight on the front) than the crane riding mower. I have lots more mods in store for it.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #30
   / Would it be possible to convert a lawn mower into a lawn "tractor" #31
Don't let naysayers discourage you from pursuing your passion. Life is a journey, with problems to solve, lessons to learn, but most of all, experiences to enjoy. The very worst that can happen is not turning out exactly as planned but guaranteed you will learn alot that will be useful on future projects.
Perhaps jaxs will agree with me that, actually, the very worst that can happen is not even trying.
I have to acknowledge my first tractor here. I was about 10 years old and my father bought me a tractor -- actually a riding mower with a 4 hp vertical shaft engine, a F-N-R transmission, a loose belt deadman clutch using an idler pulley controlled with a pedal, a chain drive to a rigid rear axle, and a belly blade. He took the blade off and put a pulley on the motor shaft, and mounted a car generator off to one side so I could have lights (at this time most cars had generators with brushes instead of alternators).
I loved that thing and rode around on it so much I wore the front wheels out (they were the hard rubber kind, not pneumatic).
If I had the room and the time, I'd probably have more like it today.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #32
That looks like a sweet tool for only $850. Too bad it is 1000 miles away for me. I do wish they posted their state, at least, on the for sale ads. I did not know IH made Cub Cadet. Then again, I am just getting into tractors both for NEED and WANT. Thank you for the site link.
IH made Cubs until about 1984ish. These little Cubs were real garden tractors. Meant to pull and push.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #33
Yes, dont let the naysayers discourage you; Pissing over the electric fence is an unforgettable life experience, go for it ! (Just video it for the rest of us šŸ¤£šŸ‘)
   / Would it be possible to convert a lawn mower into a lawn "tractor" #34
That would be an interesting video.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #35
For the utility of having a much more capable "tractor" to use? NO!
For the fun and challenge of doing the conversion? YES!
Bruce
   / Would it be possible to convert a lawn mower into a lawn "tractor" #36
IMO both should make interesting videos and I wager the lesson in the electric fence deal would last a life time.😳
   / Would it be possible to convert a lawn mower into a lawn "tractor" #37
A cheap riding mower is too light to ever preform like you intended. You’d be a lot better off to buy something that was actually built to preform that work. Buy a rough one and restore it if you want a project.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #38
Oh boy i remember this city kid 20 years ago...we warned "watch out where you piss Harm, that wire is live !" He frowned and said "Heh, you arent serious, are you ? Nothing will happen, right ?" He shrugged and said "naah you guys are just pulling my leg" So we said, "well suit yourself then: try and find out"
He aimed, got a shock, exclaimed "ooh!" Let go of his weener, which, because he contracted due to the shock, slid back in his pants, so once the contraction of his muscles (including his sphincter) went over in half a second, he wet his pants and couldnt stop, he cried "you should have told me" while we laughed "we did !!" while he cried and laughed along with us at the same time...
Yes, definately i do remember... 🤣🤣🤣🤣
   / Would it be possible to convert a lawn mower into a lawn "tractor" #39
Well, I bought three lawn mowers (lawn tractors if you wish) and got two of them running, After driving the Craftsman with the 15.5 HP up a very steep part of my back yard I can say, it is probably not ideal for pulling because it could barely pull itself. The one I am keeping for myself to haul a small firewood wagon with two trash barrels full of wood and other mundane tasks is an older 12.5HP Murray without a deck.
It looks like someone had attached plates for an implement of some sort, see the pictures below. I plan on putting on a 2" ball and plate with 5/8" holes so I can tow a small trailer and maybe the various things they make for small lawn riding lawn mowers that have the 1/2" pin.
In terms of power, a gas 15 HP B&S (peak at 3600 RPMs, probably 10 HP at 3000) is in no way shape or form in the same category of a Kubota 13 HP diesel, imho.
The riding lawn mowers, many use a Tuff Torq axle rated for 500-650 # of weight driven by basically a 1/2" V belt. These belts tend to slip when using a 140-160 AMP alternator which is one reason why you find serpentine belts in modern cars. On older trucks they use to have dual belts for high output alternators because there is only so much torque you can apply to a 1/2" belt before it slips. The same applies to a hydraulic trans-axle in a riding lawn mower.
I hope to make a vehicle that can run implements and have a 4x6 or 6x6 vehicle. I was going to use either riding lawn mower axles or ZTR trans-axles attached to 1/4" steel frame. BUT, even these ZTR axles look too weak for off road dirt work. Now, Tuff Torq does make an axle for tractors that can handle 1,000+ pounds and has a locking differential, but, I am not buying one new$. surpluscenter does have a set of axles for articulated steering that look perfect and cost just the same as the ZTR set.
I probably will make a 4x6 or 6x6 Snapper using two snappers held together using 3/16 or 1/4 angle and channel and maybe I will put on a back plate for better implement attachment, but, that is a project for light duty work. I would not use it for a three point hitch for drilling holes or dragging a plow.
I would use your skills on a platform with better bones then trying to turned a mass produced commodity bought at a box store into something it was never meant to be.
Individual rear brakes instead of diff lock. 8n did not have diff lock. Fill tires, put snow chains, get after it.
   / Would it be possible to convert a lawn mower into a lawn "tractor" #40
Anyone here that hasn't heard the story about the room full of monkeys with a football?
Kid was bored with playing football by himself when he spotted a room full of monkeys and tossed the football through the window. To his delight every monkey in the room tried taking control of the ball. After a few minutes of watching monkeys he went home but the monkeys continued wrestling over the ball until they finally wore the cover off several days later.
OP started his first and only thread 4 days ago and hasn't even looked in since,much less participated in his own thread. He tossed the ball in then moved on looking for another adventure.
2013 Ford F-450 Dump Truck (A59230)
2013 Ford F-450...
CAT 930M (A58214)
CAT 930M (A58214)
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2017 Ford F-650 Service Truck (A59230)
2017 Ford F-650...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
flatbed trailer 24ft (A56857)
flatbed trailer...
