beenthere
Super Star Member
- Joined
- Aug 16, 2001
- Messages
- 18,589
- Location
- Southern Wisconsin, USA
- Tractor
- JD_4x2_Gator, JD_4300, JD_425, JD_455 AWS, added JD_455, JD_110, JD_X485(sold)
But rather the top link is under compression when ground-engaging attachment is used, such as a plow, not tension. just sayin... The pulling is done by the lower arms.Often the multiple holes aren’t primarily to adjust the top link height, but to adjust the sensitivity, or range, of the draft control.
That is, the mechanism that measures the draft (or pulling force) is by pulling on a “lever” that’s part of the top link connection assembly. How the top link pulls on this connection is a measure of the draft. Where the top link is connected on this “lever” (top, middle, low) either multiples or reduces the measured force being sensed by the draft control… if that makes sense.
