2515H Back up lights
/ 2515H Back up lights #1
esz
Member
Colorado
Kubota L2550DT Kubota BX2200D Branson 2515H
Anyone know how to get the back up lights on a 2515H to work? They do not come on when reversing.
/ 2515H Back up lights #2
I don't think those are meant to turn on, at least on the H models from what I've seen on the forums and Facebook groups.
/ 2515H Back up lights #4
The bulb and wiring should be there, you would have to engineer a switch somewhere to activate them, on an HST maybe the "back up" pedal.
On a shuttle some kind of switch on the shuttle.
I think I recall seeing a post somewhere and someone had done this, may have been a different brand though.
/ 2515H Back up lights #5
Is this a European thing to have back up lights on tractors? I have never heard of or seen them here in this part of the USA. My first thought was rear work lights operated by the light switch.
/ 2515H Back up lights #6
Not at all. I don't even understand why Branson would use that rear light assembly with reverse lights in the USA either.
The European Bransons just come with marker, brake and flashers on the rear light assemblies. There is a place for a possible reverse light but it's blocked with a black cover.
/ 2515H Back up lights #7
PT
Appreciate that bit of information. Mine I would tie them to the high beams for rear work lights or on a separate switch especially since my 2400H has nothing factory for rear work lights.
Thanks. If I'm going to go through the trouble of wiring something up, I'll just install some rear work lights. That's what I wanted anyway.
2025 DOWN 2 EARTH GOOSENECK TRAILER (A65054)
2025 DOWN 2 EARTH...
1995 CATERPILLAR 140G MOTOR GRADER (A65053)
1995 CATERPILLAR...
JOHN DEERE 7800 TRACTOR (A65054)
JOHN DEERE 7800...
More info coming soon. (A64557)
More info coming...
2004 IC Corporation 3000IC School Bus (A64194)
2004 IC...
GODWIN 6 HEAD PUMP (A65643)
GODWIN 6 HEAD PUMP...
