Starlink
/ Starlink #2,961
I moved it up when I put the permanent mount on today.
/ Starlink #2,964
Greeting guys. I'm sorta new here. I'm brand new to this Starlink thing. Been on the wait list for a year.
I just got notice my order is preparing. I got the residential pkg.
I have been struggling for 40 yrs with crappy internet. So excited.
So tell me what am I getting into and what should I expect?
/ Starlink #2,965
Expect easy installation and blazing speeds.
/ Starlink #2,966
Seriously !? Are you just pulling my leg ? I read the northern US gets the best coverage and speed.
I'm in Southern CA 150 mi north of Mexico
/ Starlink #2,967
Wow... 40 years is a long time...
Very interested in hearing about your install and performance once it's failed in.
/ Starlink #2,968
Definitely compared to your modem of 40 years ago.
But so easy, it almost has no instructions, just follow the pictures. Try for location with no obstructions.
/ Starlink #2,969
40 years (oops) I guess we haven't had internet that long but I been here in places of poor reception since the inception (y) :LOL:
/ Starlink #2,971
I started with 300 and later moved to 1200 baud…
Living Large…
My Apple II circa 1980 has never crashed or needed to be rebooted either.
Loved the 40 character green screen too! Not
/ Starlink #2,973
This morning I have no Starlink Internet connection and there is something unusual in my wifi settings, a network called "stinky." I first did a reset on the router (unplug 3 times) then tried to setup the router with network name and password, but it was not finding the SL router.
I do have the ethernet adapter plugged into my mesh network, so I removed the network adapter and plugged the dishy cable directly into the SL router. There is no recognizable Starlink router that appears in my wifi connections, only STINKY and my mesh networks.
I selected the STINKY network and the SL "Create Network" page appears, but at the very top of my phone screen there is text saying captive.apple.com STINKY then the Create Network screen appears.
There is also text at the bottom of the screen that I have not seen in past restarts of the system.
Any idea what is going on here?
/ Starlink #2,974
Easy install and setup. Plug & play. Find the best location for an unobstructed view. For me routing the wire under and into the house was my biggest hassle. I paid a neighbor’s kid to crawl under there. 😂
/ Starlink #2,975
HOWTO Factory Reset Starlink Dish & Router
If you encounter any issues during the setup or use of your router, you can factory reset it. The router will take a few minutes to reboot, and will require you to reconnect and set a new Network ID and Password.
Circular Starlink: Gently push the button on the bottom of the router until the light turns blue and release.
Rectangular Starlink: Power cycle Starlink (unplug the router from power and then plug back in) 3 times in a row. The router will take a few minutes to reboot, and will interrupt your service until you set up again. You can expect the light on the bottom of the router to be illuminated when complete. There are no lights on the front of the router.
So starting with the unit unpluged from the power source, plug it in and unplug it 3 times and it should clear and go back to factory default settings.
You may wish to uninstall your phone app and reinstall it clean.
One moment, please...
Also it looks like you got a good reset STINKY is on of the default names with no passwaord required according to the above link.
/ Starlink #2,976
THANKS! I reconnected at things are working again with a direct connection to th SL router. In the past I did not use bypass mode with my mesh system and everything worked fine. So, I'm going to try that again and plug the mesh into the ethernet adapter and hope things work as they did before, but thanks for the info on the STINKY name.
/ Starlink #2,978
Living Large…
My first was an Osborne, a sewing machine like computer that was pricey for the day and ran the CPM operating system.
Massey Ferguson 10 Square Baler (A65640)
Massey Ferguson 10...
2022 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2022 CATERPILLAR...
2011 Ford Expedition SUV (A64557)
2011 Ford...
(4) Texas Built 25' Stand Alone Livestock Panels (A66408)
(4) Texas Built...
40ft 10 Door Shipping Container (A64194)
40ft 10 Door...
Wagon Wheel Rocking Chair (A65583)
Wagon Wheel...
