TC35 steering connector rod bent upwards, removal, adjustment etc.
   / TC35 steering connector rod bent upwards, removal, adjustment etc. #1
Parfleche
WA
NH tc35a
Hi Folks,
My steering connector rod is bent upward and wearing against a cover on the front differential casing. It has a jam nut holding the adjustment at each end. I think the jam nut on the left side is a left hand thread. What is the best way to break the jam nut loose at each end? I have tried using to large adjustable wrenches with a pipe for leverage to no avail. (Wrenches jaws stretched to much.) I could unbolt the whole assembly from the hub assembly at each side, but was trying to work around that option. Thanks in advance for your thoughts.
Kind Regards,
Steve
   / TC35 steering connector rod bent upwards, removal, adjustment etc. #2
It may be easier to just take the tie rods off the knuckle. As to what one is left hand thread or if theres one just look at the threads.
I did this same job on my tc40 about a month ago. I hope you have a hydraulic press to make it straight.
   / TC35 steering connector rod bent upwards, removal, adjustment etc. #3
Hi Folks,
Kind Regards,
Steve
Any way you can apply some heat to at least break the paint bond?
2012 Ford F-550 Crew Cab Truck (A54814)
2012 Ford F-550...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A52472)
2014 FORREST RIVER...
2016 Club Car Carryall 1500 4x4 Utility Cart (A53424)
2016 Club Car...
2012 VOLVO BL70B BACKHOE (A51246)
2012 VOLVO BL70B...
2023 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2023 Ford F-150...
2020 CATERPILLAR 745 OFF ROAD DUMP TRUCK (A52707)
2020 CATERPILLAR...
