Lighter weight log chains -- where to buy?
   / Lighter weight log chains -- where to buy? #61
Our mini choker gets worked again today. The tow machine was not worn out either. :giggle:
   / Lighter weight log chains -- where to buy? #62
One issue I have with cable chokers is that there is usually too much slack [or length] remaining after choking the log and after winching in they will still drag; whereas a chain choker can be shortened up to the log butt and the winch will then lift the log off the ground for easier skidding.
This assumes that you are not skidding very large logs [30 inch +diameter] and are using an arch of some kind.
   / Lighter weight log chains -- where to buy? #63
You can buy them in different lengths.
   / Lighter weight log chains -- where to buy? #64
I don't where you are from but most hard woodstore have some if not any rigging and wire rope specialists like Sling Choker or store like tooltown, Acklands Grainger or princess auto, have chains for sale they cut it to length and buy the hooks separately.
   / Lighter weight log chains -- where to buy? #65
Light weight choker chains work GREAT! Are easy to store and not expensive so we're sticking with them.
   / Lighter weight log chains -- where to buy? #67
I see no sense in buying a bunch of wire rope chokers in different lengths, when I can just use a choker chain, that can easily be used in any of those same lengths, plus it's just so much easier to carry around.
SR
   / Lighter weight log chains -- where to buy? #68
SR
Although I agree with this statement I know that cable chokers have their place for certain applications.
   / Lighter weight log chains -- where to buy? #70
I think using them on the big wood out west is more likely.
sure but not only that, I find cable less prone to slide off the bark when skidding multiple logs, less prone to unhook and easier to slide under heavy logs then chains.
2017 Chevrolet Tahoe SUV (A56859)
2017 Chevrolet...
2016 Freightliner Bucket Truck (A55973)
2016 Freightliner...
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A57880)
2012 FREIGHTLINER...
2007 Ford E-350 Passenger Van (A55973)
2007 Ford E-350...
2005 Chevrolet Impala Sedan (A56859)
2005 Chevrolet...
2020 CAT 308 (A53317)
